ROO90 Occasional Visitor
Posted: Mon Mar 17, 2014 5:03 pm Post subject: Comand will not load sd card |
I have the Ntg4.5 command in my 2013 e class , the system will not load from the sd card have been trying all day but with no success |
M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Mon Mar 17, 2014 5:16 pm Post subject: |
Have you have been exactly following the instructions here especially step 8? If so, it might be good to mention at which stage it fails. |
Posted: Mon Mar 17, 2014 5:57 pm Post subject: |
M8TJT wrote: | Have you have been exactly following the instructions here especially step 8? If so, it might be good to mention at which stage it fails. |
Could you advise as regards the term unpack, I extracted the files or so I think The files do not start to unload at all |
Posted: Mon Mar 17, 2014 6:56 pm Post subject: |
Unzip or extract is another word for it. It's these Apple fanboys that use terms that not many people understand. I'm surprised that it bandied about here as the downloads come in the *.zip files and thus require un-zipping.
At which point is the procedure failing? |
Posted: Mon Mar 17, 2014 7:17 pm Post subject: |
M8TJT wrote: | Unzip or extract is another word for it. It's these Apple fanboys that use terms that not many people understand. I'm surprised that it bandied about here as the downloads come in the *.zip files and thus require un-zipping.
Comand does not start to import data when sd is inserted |
Posted: Mon Mar 17, 2014 7:46 pm Post subject: |
Then it seems like it is possible that you are doing something wrong.
Have you got the folder name right in step 1? It should be PersonalPOI. Note: No space.
Have you unzipped the files into the PersonalPOI folder. It should now contain, amongst others, files names pocketgps_uk_sc.gpx and pocketgps_uk_pmobile.gpx. Can you see these two files on the SD card?
If so, at which step does it not do what you are expecting it to do. (Use the step number in the instructions as a reference)
From the instructions, Command will NOT automatically start to import the data when the SD is inserted. You have to do the stuff in the instructions, like steps 20 - 23. Are you doing this? |
Posted: Mon Mar 17, 2014 8:07 pm Post subject: |
Yes I can see the files on sd card, but step 24 does not happen |
Posted: Mon Mar 17, 2014 8:36 pm Post subject: |
Ah, right. I don't have the Merc system, so can't really go any further. If you are absolutely sure that you have the correct folder name and the correctly named *.gpx files within that folder on the SD, then the only things that I can suggest further is that you delete all the other files out of the POI folder on the SD except the *.gpx files and/or try a different SD card.
Just had another thought. Thinking out loud really. Are you using an SDHC card and if so, does it matter or should it be a bog standard SD card? Should the 8Mb suggestion in the instructions be 8Gb? Anyone??? |
Posted: Sat Apr 19, 2014 7:02 pm Post subject: |
BUMP
Still need help with this , have tried all the above suggestions all to no avail command system will not import data from SD card
Any Merc owners able to help ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
GerryC Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/web.jpg)
Posted: Sat Apr 19, 2014 7:46 pm Post subject: |
Just a thought. When extracting/unzipping/whatever the files, are they going into a sub-folder of PersonalPOI or staying in the same folder? I don't have the system but suspect they need to be in the folder itself and not a sub-folder.
Some extraction utilities will create a new folder by default unless you tell it otherwise. Is also try using an otherwise blank SD card just in case it makes a difference.
Gerry |
Posted: Mon Apr 21, 2014 8:04 am Post subject: |
pam3059 Occasional Visitor
![](modules/Forums/images/avatars/gallery/011.gif)
Joined: Jun 20, 2014 Posts: 1 Location: United Kingdom
Posted: Thu Jun 26, 2014 9:28 am Post subject: Mercedes command Help |
Did you manage to solve your problem, I am having the same trouble with my 2013 E class ??. |
Posted: Thu Jun 26, 2014 12:22 pm Post subject: Re: Mercedes command Help |
pam3059 wrote: | Did you manage to solve your problem, I am having the same trouble with my 2013 E class ??. |
Yes have it all working now.
After you have downloaded the file , then extracted it you will see a file with
Need Help
Licence
Pocketgps uk mobile
Pocketgps-uk-sc GPX File ........this one only
Release
RENAME the Pocketgps-uk-sc GPX File only to PersonalPOI then copy or move to the PersonalPOI folder on the SD card
Good Luck worked for me |
