Kremmen Pocket GPS Verifier
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Sun Feb 02, 2014 6:47 am Post subject: |
I did purchase an additional 4Gb card to be safe as mine was getting close to capacity after the first map update. I didn't check space after the last update.
I'll check later in the week when I update my cams. _________________ Satnav:
Car Average MPG :
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4458 Location: West Sussex
Posted: Sun Feb 02, 2014 9:39 am Post subject: |
wibbley wrote: |
However now it has only 393MB free and some new files on it, one of which is called gmapprom.gma which is 3,441,344k.
Are you sure? That size indicates it's the map file so will be a .img file. The .gma and .unl files are map authentication and unlock files. They're both quite small files.
I'd also expect the complete map to be on the card and not split between the card and GPS. |
wibbley Regular Visitor
Posted: Sun Feb 02, 2014 12:03 pm Post subject: |
erm, yeah, an img file
on the SD card which only had POIs on it till the latest update now has a folder called garmin and in it, 4 files
gmapprom.gma
gmapprom.img
gmapprom.unl
gmappupdate.gsd
.img being the biggie and the others only 3,1, and 0 k in size.
The original map file that came loaded on the sat-nav is actually bigger at 3,391,963 KB
There are some big files in the System directory on the internal memory. Are they needed and are there any I can delete to free up enough space to get the map back onto the internal memory? I have 2GB free, thus need to clear just under 4GB. |
Posted: Sun Feb 02, 2014 1:50 pm Post subject: |
Any big files there will be needed. Things like junction view files. |
CDK Regular Visitor
![](modules/Forums/images/avatars/14811659385159b0328f5bc.jpg)
Joined: Apr 20, 2006 Posts: 122 Location: Ashford. Kent. UK.
Posted: Thu Feb 06, 2014 2:24 am Post subject: |
sussamb wrote: | CDK wrote: |
Got a message that:
"Internal memory is almost full. You may want to purchase a memory card for this device to ensure sufficient space for future updates"
Well, I DO have a memory card inserted into the device!
For the life of me I cannot get this software to recognise the SD card, even though I can see and read it in Windows explorer. The SD card has 7GB free on it.
Check it's formatted FAT32. Note though that Express will only use it if there isn't enough internal space. Sounds like there is at the moment. |
SUSSAMB YOU ARE A CHAMPION!
I refer to your answer to my 1st Feb post about not being able to load the latest map update despite there being enough space on the SD card. Well the internal memory was only 99% full - so there was still some left. So I filled the JPG folder of the internal memory with various photo files, etc to fill it up to 100%. Express still reported that there was not enough memory. Tried "Mapupdater" - same result. To say that I was filled with deep despond (Frankie Howard?) would be an understatement. Not to mention various choice words. So deleted the 'filler' files - back to the drawing board.
Then - I saw sussamb's post about googling 'Garmin Nuvi Clone'
This brought up a website with full and clear instructions on what to do, by taking out the SD card from the satnav, and inserting it into the PC's card reader and what to do to make Mapupdater think it was connected directly to a Nuvi. (I believe it used to be called 'going over the back fence').
Used the update 'PC and Device' option, and Hey Presto! the process worked and the Western Europe map files were transferred to the PC and SD card (in the PC's card reader) within about 45 minutes.
Popped the SD card back into the Satnav and to my great relief everything worked!
Did a trip of about 50 miles today - motorway and rural - and everything was fine.
As to why the Express/Mapupdater did not work directly is a mystery.
Lets' see what happens at the next update.
So thanks to sussamb for the advice.
Not sure if I am allowed to mention the name of the website but thanks to them, too.
Posted: Thu Feb 06, 2014 9:07 am Post subject: |
Well Express should have realised the card was there, but glad the clone method worked. I use it everytime as no danger then of my satnav being messed up ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Thu Feb 06, 2014 9:35 am Post subject: |
CDK wrote: | despite there being enough space on the SD card. Well the internal memory was only 99% full - so there was still some left. | Do the words 'only' and '99% full' really sit comfortably in the same sentence? |
Posted: Thu Feb 06, 2014 5:10 pm Post subject: |
seems the most sensible option to update maps on a sd device as per sussamb's method. Having a spare card would allow a fallback if it all went south. I rely on sat-nav every day so would be stuffed if it went down.
Have tried googling garmin nuvi clone, but do not seem to find the website described. Plenty of forum posts about it though. I don't see the harm in posting the link here. It is not as if we are trying to do anything underhand.
It is strange that garmin express elected to put the new map on my sd card rather than on the device, even though the new map is smaller than the old. However I have less space than I should on the internal memory now the map is on the sd card, so I wonder if additional files were put on the internal memory.
Still get Maccy D appearing over my new map :o( I have emailed garmin my complaint about it several times.
As far as sd cards go, have seen on an unrelated forum of how larger sd cards up to 64GB have been formatted to fat32 so they work with devices that otherwise would be limited to a smaller sd card.
https://www.sdcard.org/downloads/formatter_4/ |
CDK Regular Visitor
Posted: Thu Feb 06, 2014 8:54 pm Post subject: |
Yes that's the one I used. Instructions are very clear and worked perfectly.
I will use the clone method again.
