Pocket GPS World :: View topic - Nuvi 1490, map freezing
Upperyardman
PostPosted: Sun Jan 19, 2014 9:55 pm    Post subject: Nuvi 1490, map freezing Reply with quote
I have been experiencing an irritating number of map freezes - resulting in a a number of missed turnings. The GPS signal is still being received, speed changes are noted.
It can be jolted back by hitting the "back arrow" then "View Map". A number of camera warnings are then displayed which have to be individually cancelled then the map resumes at the correct point.
All very irritating and distracting
Any suggestions would be appreciated before the unit (which has been very good up-till-now) is binned.
Regards etc
PostPosted: Mon Jan 20, 2014 8:04 am    Post subject: Reply with quote
I take it software is up to date?
I'd try a master reset http://support.garmin.com/support/searchSupport/case.faces?caseId=%7B55ec7d60-0a57-11e1-73d0-000000000000%7D
PaulB2005
PostPosted: Mon Jan 20, 2014 3:00 pm    Post subject: Reply with quote
How many POI categories do you have loaded?
SQUARE2024
PostPosted: Mon Jan 20, 2014 3:10 pm    Post subject: Reply with quote
From experience with my 1490 do a master reset,should remove your problem
Square2024
TomTom 520
Christmas Draw 2010 Grand Final Winner Garmin Nuvi 1490TV
Upperyardman
PostPosted: Mon Jan 20, 2014 3:52 pm    Post subject: Nuvi 1490, map freezing Reply with quote
Paul,
there are three entries under POI:
Speed Cams.gpi
My Garmin.pdi
POI.gpi
PaulB2005
PostPosted: Mon Jan 20, 2014 7:58 pm    Post subject: Reply with quote
Ok
Assuming poi.gpi contains the POIs you have loaded how many categories did you load?
Ie petrol stations, supermarkets, speed cameras etc?
In other words how many CSV files are putting through POILOADER?
Upperyardman
PostPosted: Tue Jan 21, 2014 10:39 pm    Post subject: Nuvi 1490, map freezing Reply with quote
Thanks Paul,
So far as I am aware, only the speed camera files from this site. I can't open the .gpi folder to check.
Thanks Guys, for the master reset idea. I have tried that - it didn't behave as expected because none of my data disappeared. No opportunity to road test today.
PostPosted: Tue Jan 21, 2014 11:07 pm    Post subject: Reply with quote
Well either the reset wasn't completed correctly or your data was at some stage sent to your nuvi and the original file (possibly temp.gpx) wasn't deleted.
22.062 (12 Jun 24)
