Pocket GPS World :: View topic - SD Card for GO Classic - Anyone with a long memory?
rkm_hm
PostPosted: Thu Dec 05, 2013 7:55 pm    Post subject: SD Card for GO Classic - Anyone with a long memory? Reply with quote
I've decided that it's about time to update the map on my 2004-vintage GO Classic.
It currently has a 1GB SD card and a Western Europe map (v6.6 - several years old, not sure exactly how old). I've just updated the software to version 7.903
The latest Western Europe map seems to be over 1GB in its own right - so I would presumably need a card of at least 2GB.
The question is, what is the maximum card size supported by the GO Classic? I copied all the existing files onto a 4GB SDHC card, and that didn't work, so I imagine that whatever card I use needs to be SDSC?
Another question: TomTom appear to have a 30% discount offer on map updates until the end of January, but this doesn't show up when I connect my device to TomTom Home. [I've only just set up an account for this particular device, but my wife has one for her (slightly) more recent TomTom One, and has received an email about the offer]. How can I get the offer to apply to me?
Thanks,
Roger
TomTom via135
Satmap Active 10+ v1.50 with full UK 1:50k map and 1:25k/1:10k County maps of Hampshire & Warwickshire
PostPosted: Fri Dec 06, 2013 8:37 am    Post subject: Reply with quote
The Classic can't use SDHC cards unfortunately. You will need an original standard SD card.
IIRC it could only handle 2GB. There's not many about now.
I've found This.
If you wanted a large Europe Map you would need to download it in Zones.
rkm_hm
PostPosted: Fri Dec 06, 2013 3:11 pm    Post subject: Reply with quote
I've found This.
Thanks for the info. I think that the Western Europe map, is about 1.3GB, so should fit on a 2GB card. The information on the TT website suggests that their Zones for larger areas are about 1.6GB so that doesn't seem appropriate in this case.
How sure are you - or anyone else, for that matter - that the Classic can actually handle a 2GB card and is not limited to 1GB? The initial, card supplied with it was only 256k (I think) and an early review mentioned 1GB in a way which suggested that it may be the limit.
Thanks,
Roger
TomTom via135
Guivre46
PostPosted: Fri Dec 06, 2013 6:08 pm    Post subject: Reply with quote
MYMEMORY is still advertising 2Gb sd cards compatible with the Go Classic.
Here
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
justbrowsing
PostPosted: Fri Dec 06, 2013 9:23 pm    Post subject: Reply with quote
Actually ALL the TT's (even the older models like this) CAN run SDHC 32Gb+ cards subject to using a slightly later bootloader file called a system file (anything from v5.5120 onwards)
I wouldn't dare point you in the right direction but try to google:-
"tomtom bootloader 5.5120" and all will become clear(er)
Guivre46
PostPosted: Sat Dec 07, 2013 11:29 am    Post subject: Reply with quote
I'd always believed, because of what I'd read here, that the bootloader application was quite complicated. I remember a post that moreorless seemed to say that once the bootloader version was upgraded it was very difficult to roll back to an earlier version. I took this to mean that there was some alteration to the software embedded on the device....
Kia In-dash Tomtom
justbrowsing
PostPosted: Sat Dec 07, 2013 1:30 pm    Post subject: Reply with quote
Changing to a later bootloader cannot harm things. Each new navcore normally has a later bootloader anyway
rkm_hm
PostPosted: Sat Dec 07, 2013 4:12 pm    Post subject: Reply with quote
Many thanks to everyone who has replied. I've managed ro scrounge a 2GB SD (non-HC) card via my local Freecycle/Freegle group, and that was fine in my TTG once I'd copied all the files fom the 1GB card onto it - so I now have plenty of elbow room for a larger map without neding to frig about with bootloaders.
Roger
TomTom via135
rkm_hm
PostPosted: Sun Dec 08, 2013 5:04 pm    Post subject: Reply with quote
I assume there must be. Otherwise it's Cache 22 - it won't recognise the SDHC card in order to read the updated bootloader from it until the updated bootloader has been installed!
Roger
TomTom via135
22.063 (19 Jun 24)
