Pocket GPS World :: View topic - NAVMAN AND TT3
NAVMAN AND TT3
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navman Handhelds
MATLOUGH
PostPosted: Wed Sep 15, 2004 3:40 pm    Post subject: NAVMAN AND TT3 Reply with quote
Has anybody managed to use BOTH these apps on the same iPAQ (4150) - not at the same time?
I can install both, but when i try and run Navman it cannot find comm port 6 (bluetooth).
Any ideas?
Thanks in advance
drummer
PostPosted: Wed Sep 15, 2004 3:49 pm    Post subject: Reply with quote
Have you tried removing the "Tomtom ~gps" from the remove programs list. If not, do this once only and restart the iPaq. It will still appear in the remove programs list but the gps should now be available to other apps. Wink
MATLOUGH
PostPosted: Wed Sep 15, 2004 3:54 pm    Post subject: Reply with quote
That lets me know select Com 6, but now TT3 says GPS Disable, unable to launch the GPS control panel
drummer
PostPosted: Wed Sep 15, 2004 4:47 pm    Post subject: Reply with quote
That's odd, that worked for me.
Are you able to select "GPS" in the setting/systems menu. If so, you may need to tick the box in the gps tab.
Failing that, try unpairing then re-pairing the gps.
If that fails you may need to re-install TTGPS. I believe that version 2.07 (available in the downloads section on this site) does not lock the com port. If you do this, you should completely uninstall the existing TTGPS from the iPaq first.
Talkingbollox
PostPosted: Wed Sep 15, 2004 9:02 pm    Post subject: Reply with quote
Hi MATLOUGH
Is that SmartST v1.96 you've got? If so, don't bother - it's sh*te IMO.
Answering your question, I did get both to work at the same time. TT3 was on COM1, Navman on BT. I only use Navman abroad - it's got maps of Europe.
Tim Buxton
PostPosted: Wed Sep 15, 2004 11:28 pm    Post subject: Reply with quote
Hi MATLOUGH,
Talkingbollox either speak with forked tongue or live up to name. V1.96 very good map. Navteq map, not TeleAtlas poor substitute.
Tim
MATLOUGH
PostPosted: Thu Sep 16, 2004 8:26 am    Post subject: Reply with quote
I upgraded to the new GPS driver which sorted it.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Navman Handhelds All times are GMT + 1 Hour
