Pocket GPS World :: View topic - remove original cyclops data from a garmin nuvi 1490T
jethro49er
PostPosted: Wed Nov 27, 2013 12:42 pm    Post subject: remove original cyclops data from a garmin nuvi 1490T Reply with quote
is is safe and possible to remove the original speed camera data (cyclops) from my garmin nuvi 1490t and if so how do I go about it please. I use the pocketgpsworld speed database but the cyclops speed icon still shows up in the bottom right hand corner of the unit, which is out of date.(not updated it with Garmin speed camera database since buying the unit)
PostPosted: Wed Nov 27, 2013 1:47 pm    Post subject: Reply with quote
Just delete the cyclops files from the POI folder, They should be obvious but if you're concerned post back with the file names in the POI folder.
jethro49er
PostPosted: Wed Nov 27, 2013 6:10 pm    Post subject: remove original cyclops data from a garmin nuvi 1490T Reply with quote
thanks for the reply..the only files in the POI folder are as follows
pgpsw-speeed-cams-q5Qq5-(11-093).gpi 19/09/2013 09:11 GPI File
UKCyclopsSample.unl 10/02/2010 13:38 UNL File
I guess its ok to delete the UKCyclops file then it is only 1KB, will this stop the speed limit icon from appearing in the bottom right hand corner of the unit?
Thanks again
Terry
PostPosted: Wed Nov 27, 2013 6:56 pm    Post subject: Reply with quote
The actual file appears to have already been deleted as it would be a .gpi file.
The speed icon is always shown, it's nothing to do with the cyclops files.
jethro49er
PostPosted: Wed Nov 27, 2013 9:34 pm    Post subject: Reply with quote
Thanks but the speed icon is never correct according to the pocketGPSWorld speedcam database
PostPosted: Wed Nov 27, 2013 10:28 pm    Post subject: Reply with quote
The speed in the lower right corner is the speed you're travelling at or the speed limit of the road according to the map data. It has nothing to do with either the cyclops or any other speed camera files.
jethro49er
PostPosted: Wed Nov 27, 2013 11:26 pm    Post subject: Reply with quote
OK get that, garmins maps supposed to be up to date but obviously not, will just have to rely on CameraAlert all of the time then
Thanks for you assistance Smile
