Pocket GPS World :: View topic - Turboccc Extra POI Editor
PostPosted: Wed Nov 13, 2013 3:06 pm    Post subject: Turboccc Extra POI Editor Reply with quote
For any of you that use Turboccc's excellent program Extra POI Editor you will be happy to know that he has reappeared long enough to update this program to fix some problems that have come up since it was last updated, a couple of years ago. The new version is available from:
http://turboccc.wikispaces.com/Extra_POI_Editor#Extra_POI_Editor
Changes from v5.32 to beta v5.35
Fixed the Geocoding and Batch Geocoding functions
Reduced the maximum POI loaded in EPE to 500,000 instead of 1,000,000.
Fixed a runtime error when hitting the Grab button before the map is drawn in the POI Edit window.
BAVC10
PostPosted: Sun Nov 24, 2013 10:43 pm    Post subject: Reply with quote
TurboCCC has updated to version 5.90.
Looks like a work in progress though.
v5.90 - Beta using the new google API v3.
- Temporary: Circles on map are no longer displayed or grabbed
- Temporary: Not possible to move marker on POI edit map or grab coordinates.
- Temporary: View POIs on Map not working
- Temporary: View POIs on Route or any other maps not supported for now.
Good news if this means TurboCCC is able to spend some time back (however little is welcomed) on this superb utility.
DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
BAVC10
PostPosted: Thu Nov 28, 2013 11:24 am    Post subject: Reply with quote
Now up to version 5.91
No release notes provided but on use you can tell it is still a work in progress and a few of the issues in 5.90 have been fixed.
BAVC10
PostPosted: Sun Sep 03, 2017 7:17 pm    Post subject: Reply with quote
This great utility is now up to version 6.04
v6.04 - Added a new search location and logic in the registry to find GE Pro exe file
Added Lon/Lat value checking when importing CSV/XLS file
v6.01 - Fixed a script error when loading streetview (compatibility issue with web browser)
v6.00 - Fixed message "You are using a browser that is not supported by the Google Maps
JavaScript API. Consider changing your browser"
v5.99 - Fixed a script error when loading streetview (compatibility issue with web browser)
v5.98 - Added ability to change the geocoding match level in Preferences. Default is street
number (door level) but can be changed to street address (street level). Helps for
some countries.
v5.97 - Fixed default circle to 30m when drawing the first time.
Fixed EPE crash when updating a bearing that does not exist.
Fixed Geocoding issue which was not returning coordinates in some conditions.
v5.96 - Added ability to view Bearing Alerts on MAP in POI Edit window. Note that EPE will use
circle list when saving to .gpi if circles are present. Otherwise, bearing list is used.
v5.95 - Added back route display in View POIs on MAP. Each route has a different color.
- In the POI Edit page, a right-click on the map can be used to move POI marker to a
new position. It is still possible to drag the POI marker.
- Fixed an issue where EPE would crash when grabbing alert circles in POI Edit window.
- Fixed an issue where the alert circles would not get redrawn after pressing the
geocoding button in the POI Edit window.
v5.94 - Added back the StreetMap View in View menu. Select one poi and check it on StreetView.
- Added back the View POIs on MAP in view menu. View all loaded POIs on the map.
- Still missing: view routes on map (feature lost since v5.91). Working on it.
v5.93 - Added back the circle list. Cool! In the POI Edit page, you can add alert circles
directly on the map. Use "Grab Circles" button afterward.
v5.92 - Beta using the new google API v.3.19.
- No additional functionalities compared to v.5.91
22.055 (29 May 24)
