Pocket GPS World :: View topic - GPS Port Closed
GPS Port Closed
jook
PostPosted: Wed Sep 15, 2004 10:21 am    Post subject: GPS Port Closed Reply with quote
Hi, can someone help me please...
I ran SmartST V2 for a while with my Fortuna Clip-on bluetooth GPS device. I then used Tom Tom 3 for 4 or 5 months. Anyway, now I am trying to use SmartST V2 again, and I am getting "GPS Port Closed" message when I try and use it. It has been a while since I last used it so I might be doing something basic wrong here.
I have the Tom Tom GPS driver on the Pocket PC (2003). I also see a GPS driver under settings.
Under serial settings for my bluetooth device its set to Com 8. The Tom Tom 2 driver (under programs) is set to NMEA 018v2 38400. This seems to work for Tom Tom. Do I need to remove this driver for SmartST to work again? Will Tom Tom still work if I do?
The GPS driver is also set to NMEA 018v2 38400, and Bluetooth Serial Port COM8. When I connect to my bluetooth device I can see the status tab working indicating that the connection is there.
When I then go into Smart ST and go to the GPS status and set the port to port 8 I get a "NO GPS DATA" message for approx 10 seconds and then "GPS PORT CLOSED" I have the rate set to 38400.
Has anyone any ideas what I am missing here? Thanks.
P.S. It used to work before I put Tom Tom on, and I am now on SP2 for Smart ST 2. I am not sure which of these could be the contributing factor (if any) for it not working.
icsys
PostPosted: Wed Sep 15, 2004 10:39 am    Post subject: Reply with quote
You have ticked the GPS box in the top left corner of the GPS Status screen haven't you?
If it is not ticked you will get the message 'GPS Port Closed'
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
jook
PostPosted: Wed Sep 15, 2004 10:54 am    Post subject: Reply with quote
Yes, I have the GPS Status ticked. It shows the uptime when I have done. When I tick the GPS box in Navman it firstly tells me "NO GPS DATA" and then "GPS PORT CLOSED"
icsys
PostPosted: Wed Sep 15, 2004 11:19 am    Post subject: Reply with quote
I remember having this problem. In fact i've just re-created it.
It happens a lot when the iPAQ switches off with the port open during a route. The only way to open the port is a soft reset.
Anyway, try a soft reset then launch ST again. Also check you have the correct baud rate.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
jook
PostPosted: Wed Sep 15, 2004 11:55 am    Post subject: Reply with quote
A soft reset didn't help. How can I find out what the baud rate should be? It is set as 38400 in SmartST using the NMEA 38400 driver.
icsys
PostPosted: Wed Sep 15, 2004 12:23 pm    Post subject: Reply with quote
The correct baud rate for the Fortuna is 38400
Do you need to use the TomTom GPS driver? What version is it? I thought it was only required if you are running TomTom software?
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
jook
PostPosted: Wed Sep 15, 2004 12:50 pm    Post subject: Reply with quote
I would like to keep Tom Tom on the pocket pc so I can use the speed camera database when I need to. I am at a bit of a loss here...
icsys
PostPosted: Wed Sep 15, 2004 12:57 pm    Post subject: Reply with quote
Check the TomTom driver you're using is version 2.07 which has a fix that allows software other than tomtom to use the GPS port.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
jook
PostPosted: Wed Sep 15, 2004 1:04 pm    Post subject: Reply with quote
Hi, I removed the tom tom driver before reading your post. It fixed the problem! Tom Tom also seems to work OK with the main GPS driver.
I'm happy now :D
Thanks very much for your help.
icsys
PostPosted: Wed Sep 15, 2004 1:09 pm    Post subject: Reply with quote
Excellent news Thumbs Up
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
22.055 (29 May 24)
