HummerUK Frequent Visitor
Joined: Apr 21, 2007 Posts: 332 Location: East Sussex
Posted: Mon Jul 08, 2013 9:30 pm Post subject: |
I see version 8.0 firmware is out now which has not helped my one (turned off while updating fuel costs).
New maps 2014 and a new voice file also. |
Posted: Fri Sep 13, 2013 8:16 pm Post subject: |
I got from Halfords a standard car power adapter rather than use the provided FM traffic one.
Since fitting this it has been perfect (I may regret saying that).
So indeed, perhaps the issue is with the FM Traffic module or the firmware update Garmin made at the same time the units started to play up.
Garmin adapter BTW was under £18.00 and cheaper than the third party ones they had.
Unrelated, I also see now when you enter a tunnel the map data switches the unit into night mode...
HummerUK |
locksmith Lifetime Member
Posted: Sun Sep 15, 2013 6:24 pm Post subject: |
Glad yours has finally started behaving.
Since swapping to the GTM35 lead mine has been perfect.
The tunnel thing is cool isn't it! |
ColinS Lifetime Member
Joined: 30/03/2003 17:56:49 Posts: 120 Location: Dorset, UK
Posted: Fri Sep 27, 2013 9:01 pm Post subject: Same issue here |
I've been having almost identical issues since doing a map and firmware update a few months ago. Before that no issues at all but now it powers off several times a day. Sometimes it takes three or four attempts to get it started up as it crashes while loading the maps.
Just installed update to 8.10 and the latest maps so will see how that goes.
If not I will try a new power lead. _________________ Colin
Honda Jazz EX-Navi MKIII |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Sun Sep 29, 2013 6:40 am Post subject: |
Sounds more like you need to do a hard reset. See the stickies if you don't know how to do that. |
Posted: Mon Sep 30, 2013 3:40 pm Post subject: |
sussamb wrote: | Sounds more like you need to do a hard reset. See the stickies if you don't know how to do that. |
Worked ok for a while but has now started it's usual tricks again. So I have taken your advice and carried out a hard reset as per http://support.garmin.com/support/searchSupport/case.faces?caseId=%7B80c3c390-85f1-11df-f376-000000000000%7D
I will post back on my success or not in a few days.
locksmith wrote: | Since swapping to the GTM35 lead mine has been perfect. |
BTW mine already has a GTM35
HummerUK wrote: | I got from Halfords a standard car power adapter rather than use the provided FM traffic one. |
Does this mean that you no longer get traffic information? _________________ Colin
Posted: Sun Oct 13, 2013 11:10 am Post subject: |
Hard reset didn't work either.
Usually happens when device is first switched on and more likely than not it then takes some 3 attempts to get it working.
I think I will just have to live with it. _________________ Colin
Posted: Sat Dec 14, 2013 3:09 pm Post subject: |
ColinS wrote: | Hard reset didn't work either.
I think I will just have to live with it. |
With the standard lead no traffic
However, since installing all the optional updates with Garmin WebUpdater it has been fine again.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
HummerUK |
