digitalker Occasional Visitor
Posted: Sun Jul 07, 2013 9:12 pm Post subject: |
That's weird!
I've been having all sorts of different messages from Camera Manager recently (POI directory invalid, Cannot log in to PGPSW, etc as well as the download error). I'm using windows 7 professional. I also noticed that my username was corrupt in the 'Account' tab of CM (had extra characters?). Fixed this, but no improvement. Kept correcting the POI directory location (it wouldn't find it even though it appeared to be the correct directory path). Still no improvement.
In desperation I changed the properties of the Camera.exe file to NOT run in XP compatibility mode (used to work like that didn't it?), but kept 'Run as Administrator' and it suddenly sprang into life!
Very odd! Anyone else had success, or am I deluding myself? |
Kremmen Pocket GPS Verifier
Posted: Mon Jul 08, 2013 6:32 am Post subject: |
'Run as Administrator' can solve a lot of problems as it opens up certain Windows directories to read/write status.
Under a limited user it's often read only. _________________ DashCam:
Viofo A119 V3 |
deeranwith Lifetime Member
Posted: Tue Jul 09, 2013 4:33 pm Post subject: |
No change here. Tried earlier versions old CM all fail in the same way. I do believe it is associated with the new server configuration in that the file downloaded is not recognised by CM.
Posted: Sat Jul 13, 2013 11:18 am Post subject: |
Sorry, been away.
I was deluding myself. The change I made meant that CM was not even attempting to download files! So of course I got no error messages.
So the problem is not fixed. |
Metblackrat Regular Visitor
Posted: Sat Jul 13, 2013 11:52 am Post subject: |
I have given up on this. Kremmen's program is better anyway when you get used to it. |
BrianR Occasional Visitor
Joined: Mar 22, 2005 Posts: 14 Location: Croydon, Surrey
Posted: Sat Jul 13, 2013 11:59 am Post subject: |
Metblackrat wrote: | I have given up on this. Kremmen's program is better anyway when you get used to it. |
Can you provide details of that please? I am getting frustrated with the non-working one from Ash as well. Disappointing as I liked it very much.
Brian |
westcatford Occasional Visitor
Posted: Sat Jul 13, 2013 12:06 pm Post subject: |
As one of the poor foot soldiers who simply uses, sorry, used, this program, and depended on it, could I add a plea for this current issue to be fixed ASAP. |
Posted: Sat Jul 13, 2013 12:13 pm Post subject: |
Metblackrat wrote: | http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=91951 |
Many thanks, I'll have a go with it.
Brian |
mars.1 Lifetime Member
Posted: Mon Aug 19, 2013 9:57 am Post subject: Camera manager fault. |
I tried to use the camera manager but its no longer running like it used to be.This seems to have been ongoing since May of this year when i look back at past posts. Has this problem been fixed to date? |
Ash10 Pocket GPS Verifier
Posted: Mon Sep 16, 2013 12:48 pm Post subject: Re: Camera manager fault. |
mars.1 wrote: | I tried to use the camera manager but its no longer running like it used to be.This seems to have been ongoing since May of this year when i look back at past posts. Has this problem been fixed to date? |
NOW FIXED...
Big thanks to MaFt  |
BAVC10 Lifetime Member
Posted: Mon Sep 16, 2013 12:51 pm Post subject: |
Ash10. That's great news. Is there an updated version we need to download??
The link still shows 3.6 final. Interesting to know what the issue was a PGPSW said that nothing had been changed from their side although the workaround to download CM3 files was a big help. _________________ DriveLuxe 51 LMT D - Firmware 6.80
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
Posted: Mon Sep 16, 2013 12:56 pm Post subject: |
BAVC10 wrote: | Is there an updated version we need to download?? |
Nope, CM3.6FR should just spring back into life...  |
Posted: Mon Sep 16, 2013 12:58 pm Post subject: Re: Camera manager fault. |
NOW FIXED...
Big thanks to MaFt [/quote]
Yes, it has worked! Many thanks.
Only slight snag is that the Camera Manager icon keeps flashing and states updates are ready for installing. This may not be a related problem though!
Brian |
vdeknock Lifetime Member
Posted: Mon Sep 16, 2013 1:11 pm Post subject: |
I am not seeing any new files in my Garmin POI directory. I have been manually downloading a zip file, renaming it and then placing a copy in this directory to trick the CM into working. Every week or when every it checks the old files get removed. I have not updates for a few weeks as the changes in Perth Australia are not that often.
Should I be seeing files?
I am also getting the flashing icon to tell me Updates are ready to be installed. Sorry to be a pain but it will be nice to not have to manually download the file and rename.
Thanks for working on getting it back working again - you only really miss the great little programs when they stop working.
Vincent |
