Pocket GPS World :: View topic - Garmin 2595LM Locks up
Goto page Previous  1, 2, 3
HummerUK
PostPosted: Mon Jul 08, 2013 9:30 pm    Post subject: Reply with quote
I see version 8.0 firmware is out now which has not helped my one (turned off while updating fuel costs).
New maps 2014 and a new voice file also.
HummerUK
PostPosted: Fri Sep 13, 2013 8:16 pm    Post subject: Reply with quote
I got from Halfords a standard car power adapter rather than use the provided FM traffic one.
Since fitting this it has been perfect (I may regret saying that).
So indeed, perhaps the issue is with the FM Traffic module or the firmware update Garmin made at the same time the units started to play up.
Garmin adapter BTW was under £18.00 and cheaper than the third party ones they had.
Unrelated, I also see now when you enter a tunnel the map data switches the unit into night mode...
HummerUK
locksmith
PostPosted: Sun Sep 15, 2013 6:24 pm    Post subject: Reply with quote
Glad yours has finally started behaving.
Since swapping to the GTM35 lead mine has been perfect.
The tunnel thing is cool isn't it!
ColinS
PostPosted: Fri Sep 27, 2013 9:01 pm    Post subject: Same issue here Reply with quote
I've been having almost identical issues since doing a map and firmware update a few months ago. Before that no issues at all but now it powers off several times a day. Sometimes it takes three or four attempts to get it started up as it crashes while loading the maps.
Just installed update to 8.10 and the latest maps so will see how that goes.
If not I will try a new power lead.
Colin
Honda Jazz EX-Navi MKIII
PostPosted: Sun Sep 29, 2013 6:40 am    Post subject: Reply with quote
Sounds more like you need to do a hard reset. See the stickies if you don't know how to do that.
ColinS
PostPosted: Mon Sep 30, 2013 3:40 pm    Post subject: Reply with quote
Worked ok for a while but has now started it's usual tricks again. So I have taken your advice and carried out a hard reset as per http://support.garmin.com/support/searchSupport/case.faces?caseId=%7B80c3c390-85f1-11df-f376-000000000000%7D
I will post back on my success or not in a few days.
BTW mine already has a GTM35
Does this mean that you no longer get traffic information?
Colin
ColinS
PostPosted: Sun Oct 13, 2013 11:10 am    Post subject: Reply with quote
Hard reset didn't work either.
Usually happens when device is first switched on and more likely than not it then takes some 3 attempts to get it working.
I think I will just have to live with it.
Colin
HummerUK
PostPosted: Sat Dec 14, 2013 3:09 pm    Post subject: Reply with quote
With the standard lead no traffic Sad
However, since installing all the optional updates with Garmin WebUpdater it has been fine again.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
HummerUK
Page 3 of 3
