bjellys Occasional Visitor
Joined: 27/06/2003 06:54:23 Posts: 36 Location: United Kingdom
Posted: Mon Sep 13, 2004 1:21 pm Post subject: Tomtom on HP jordana 540 series Help needed |
Hi a mate has just purchased a HP jordana 540 with gps receiver and wants to put Tomtom on it . The Jordana is running windows CE,does he have to run an old Tomtom version or will a new version be ok.Is it possible to upgade the OS system on this model. thanks in advance bjellys. |
lbendlin Pocket GPS Staff
Posted: Mon Sep 13, 2004 2:00 pm Post subject: |
It certainly doesn't hurt to first try with an older version (say 2.24) If that works then you may be adventurous and also try with 3.03
Note that you will need a different compilation, though, because the Jornada hasa different processor type.
Also, make sure to put as much of your programs as possible onto storage card - you need as much free RAM as possible to run TomTom on that old machine. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Pc-Mobile Frequent Visitor
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
Posted: Tue Sep 14, 2004 4:26 am Post subject: Re: Tomtom on HP jordana 540 series Help needed |
bjellys wrote: | Hi a mate has just purchased a HP jordana 540 with gps receiver and wants to put Tomtom on it . The Jordana is running windows CE,does he have to run an old Tomtom version or will a new version be ok.Is it possible to upgade the OS system on this model. thanks in advance bjellys. |
You cannot upgrade the OS. But Tom Tom 2 runs OK in it and I think Tom Tom 2 is quite adequate for navigation use. _________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Posted: Tue Sep 14, 2004 4:28 am Post subject: |
Having said that, is 540 32MB or 16MB?
I know 548 is 32MB.
32MB is OK, 16MB probably not. _________________ Pc-Mobile
Posted: Tue Sep 14, 2004 10:05 am Post subject: Tomtom on HP jordana 540 series Help needed |
I have now tried tomtom2 and It says on the Jordana screen ( this verion will not run on CE ) |
Posted: Tue Sep 14, 2004 1:29 pm Post subject: |
Make sure you try the right executable. The Jornada (NOT Jordana) doesn't have an ARM processor - it's either MIPS or SH3 _________________ Lutz
Posted: Tue Sep 14, 2004 2:51 pm Post subject: |
Is yours CE2.0 or 3.0? May be 540 is 2.0?
I had intalled on Jornada 548 which was 3.0 without any problem.
Tom Tom 2 should run on 3.0. I do not think the processor makes any difference and Tom Tom just install itself.
If it is CE2.0 then you cannot run it. _________________ Pc-Mobile
Posted: Tue Sep 14, 2004 7:13 pm Post subject: Thanks |
Thanks all
and thanks lbendlin I installed the arm setup ( silly boy ) I will now try the other setups and see which is the right one. Thanks again bjellys |
