Pocket GPS World :: View topic - Bought my first Garmin today
keithmillar
PostPosted: Tue Aug 20, 2013 11:31 pm    Post subject: Bought my first Garmin today Reply with quote
Hello,
I took the plunge today and bought my first Garmin Sat Nav today and went for the 3598LTM-D.
My next step is to start loading up the PGPS speed camera updates. Is there anything I should know about how to do this, as I've never used the POI Loader, but having read up on it and watch the video it looks to be straight forward.
Any hints and tips would be appreciated
Keith
Keith
Garmin 3598LTM-D
Android CoPilot
Navigon 72 Plus Live
TTGO540
PostPosted: Wed Aug 21, 2013 7:05 am    Post subject: Reply with quote
All I know is at some stage you MUST get the units right as mph instead of km.
keithmillar
PostPosted: Wed Aug 21, 2013 8:17 am    Post subject: Reply with quote
Thanks for the tip DennisN. Smile
Does anyone know how you save your location and add to favourites Question
Keith
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
BAVC10
PostPosted: Wed Aug 21, 2013 3:41 pm    Post subject: Reply with quote
Keith
Favourites are easy to add, type in the address and you have an option to save.
Alternatively, you can tap the vehicle icon and it will give you an option to save your current location
DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
keithmillar
PostPosted: Wed Aug 21, 2013 11:07 pm    Post subject: Reply with quote
BAVC10 wrote:
Keith
Thank you BAVC10 - what an easy way Very Happy
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
keithmillar
PostPosted: Thu Aug 22, 2013 8:46 pm    Post subject: Reply with quote
I used my 3598LTM-D today for the first time, and was please with the results.
I spent most of last evening download the latest speed camera updates and then using Kremmen CSV to GPX Converter, I loaded them onto the devices with the POI Loader.
I even download one of the free voices from the PGPSW website as well.
However I just have one question - when approaching a speed camera, why does the onscreen banner sometime show as red and then sometimes as grey Question
Keith
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
BAVC10
PostPosted: Fri Aug 23, 2013 11:43 am    Post subject: Reply with quote
If you are speeding it will be RED - as will the Speedo display in the bottom left turn red. Grey is when you are under the specified speed limit.
You can disable the pre-installed speed cams and install the PGPSW ones (using ASH10 program (see sticky)) as this allows you to set the 10% tolerance which the police use (Garmin's one are set at the actual speed limits).
keithmillar
PostPosted: Fri Aug 23, 2013 12:00 pm    Post subject: Reply with quote
Thanks BAVC10 for the info - appreciated
I've looked at the sticky for ASH10 program, but there would seem to be some problems with it, looks as if there’s been ongoing from May of this year onwards. So i'm a bit reluctant to downloaded if it’s not working properly.
Keith
Keith
Garmin 3598LTM-D
Android CoPilot
TTGO540
BAVC10
PostPosted: Fri Aug 23, 2013 5:19 pm    Post subject: Reply with quote
Ash10 prog works well - just not as automated in the past as you now need to do a bit of filerenaming. Nothing too onerous once you select the CM option in the drop down box
22.063 (19 Jun 24)
