Pocket GPS World :: View topic - Nuvi 3598-D First impressions / Latest firmware (4.80)
Goto page Previous  1, 2, 3 ... 5, 6, 7 ... 20, 21, 22  Next
michaelj2
PostPosted: Thu Aug 15, 2013 10:28 am    Post subject: Re: Garmin 3598 Reply with quote
michaelj2 wrote:
I have one comment and one problem.
I cannot pair the device with my Iphone 5 but can pair easily with either of my iPads! My Iphone can "see" the Nuvi and the Nuvi give me a code which is seen by the Iphone but pairing fails each time. Any help would be appreciated.
BTW I have paired my Iphone with my car and other devices without any issues before. I have deleted these pairings just to see if that would work, but alas it does not.
After much searching without an obvious solution, I finally reverted to doing a re-install which resolved the problem! Not sure why or how, but it now works.
Still finally vexing problem, why are the Michelin Restaurants and Hotel not compatible with the 3598 yet they are compatible with the 3597? I sent a query to Garmin customer service but the silence is deafening.
BAVC10
PostPosted: Thu Aug 15, 2013 10:53 am    Post subject: Reply with quote
Not sure why there is an issue with the POIs as the 3597 and 3598 are the same model apart from the digital traffic receiver and a few files which reside within the system directory to support the traffic but this shouldn't affect the POIs
DriveLuxe 51 LMT D - Firmware 6.80
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
BAVC10
PostPosted: Fri Aug 16, 2013 11:48 pm    Post subject: Reply with quote
The initial Halfords stock of 3598-LMT-D were labelled 3597 on the serial number sticker and began with a 2 followed by two letters (WT) then numerics. The latest stock begins with 39 followed by a letter (Q) then numerics and is labelled 3598 on the back.
In both models, the unit showed 3598 when booting up and both my units came with a 4gb micro SD card.
The latest software (3.20 onwards) has an option to connect Bluetooth for Smartphone services but to use another source (or phone for calls) via a new tickbox option. I.e. phone calls can route via an in-car speaker or headset rather than the Nuvi.
As others have commented, Garmin Express (and webupdater) seem to want to update the Language Text to version 1.40 every time (Garmin Express is worse as in the advanced settings it wants you to install 6 or so files you already have on your Nuvi).
StumpyBloke
PostPosted: Sat Aug 24, 2013 5:00 pm    Post subject: Speaker Hiss Reply with quote
Hi all,
I've just had my second 3598 due to the same problem(?) of a bit of speaker hiss, both from the inbuilt one and the mounting unit. Could you please confirm if yours (or the 3597?) does it?
Its fully updated and did it before the update to 3.30.
Thanks, Richard
BAVC10
PostPosted: Sat Aug 24, 2013 5:03 pm    Post subject: Reply with quote
Not had any problems with any of my 3598's.
Is yours a 3597 model but sold as a 3598 (by Halfords) with a 2WT serial number (on the box/back of unit) or a "true" 3598 with a serial number beginning 39Q0..... as this is the later version?
StumpyBloke
PostPosted: Sat Aug 24, 2013 5:07 pm    Post subject: Reply with quote
Hi.
Its a 3598 from Halfords with serial number beginning 39Q0xxxxxx.
It seems to be functionally fine but has a hiss when your ear is quite close to the speaker(s). Both the first and this unit also made slight 'electronic noises', again quiet though, when starting up.
Are yours completely and utterly silent then, even when your ear is close to the built in speaker?
Thanks, Richard
StumpyBloke
PostPosted: Tue Aug 27, 2013 4:25 pm    Post subject: Reply with quote
Anyone please?
BAVC10
PostPosted: Tue Aug 27, 2013 4:34 pm    Post subject: Reply with quote
My unit is generally silent. No hiss.
I occasionally get an "electronic interference" noise - like the type a radio will pick up when there is a mobile phone nearby.
What volume do you have the speaker set at? I find 50 or 55 about right and have the volume control for speed checked.
I'll turn the volume to 100 tonight and see if I can hear anything "unusual"
StumpyBloke
PostPosted: Tue Aug 27, 2013 5:25 pm    Post subject: Reply with quote
Hi. Thanks for getting back. It's just a general hiss all the time. Some people would probably only hear it with their ears right up to the speaker unit. Of course, it's absolutely inaudible when in the car Smile
jonstatt
PostPosted: Wed Aug 28, 2013 5:00 pm    Post subject: Reply with quote
I reported a fairly major bug to Garmin today.
If you have the digital traffic enabled with the cable AND you also have traffic enabled on a smartphone using the Garmin Smartlink application, the 3598 gets very upset indeed. It flicks between both traffic connections over and over (which don't have the same information), and then eventually causes the 3598 to crash/reboot.
Garmin are looking into this.
The problem is you cannot switch off this functionality on the app once it has been purchased. I actually want the smartlink primarily for the speed cameras but you cannot choose which bits of functionality you want.
You may want both traffic connection types when you are travelling to places where there is no DAB coverage, or in parts of Europe etc.
BAVC10
PostPosted: Wed Aug 28, 2013 5:11 pm    Post subject: Reply with quote
There was something in a recent firmware update about Smartphone links and traffic compatibility as well as something on adding a new function to just use the Smartphone for Smartlink rather than phone via the sat nav.
Will be interesting to see what Garmin come back with.
michaelj2
PostPosted: Thu Aug 29, 2013 6:10 pm    Post subject: 3598lmt Reply with quote
i have not seen this behaivour and I have both enabled. Lets see what Garmin say.
I did get a reply back from Garmin about the Michelin guide and have told me that the 3598 is now compatible with the guides but unfortunately its not been updated on the website yet
daveg247
PostPosted: Sat Aug 31, 2013 11:32 am    Post subject: Reply with quote
So maybe looking at getting one of these, what the customisation like, I know when I had my TT 540 use could add your own Poi including your own icons which could be dragged and dropped through windows, but as models have got newer there seemed to be less access.
Also with the 3D car icon are you able to create your own vehicles ? Cheers
StumpyBloke
PostPosted: Sun Sep 01, 2013 11:53 am    Post subject: Reply with quote
I can't really comment on the customisation options but I've had mine to replace a TT Live 1005. The main improvements for me compared to the TT are the lifetime maps and traffic and the responsiveness of everything on the unit. The TT was so slow. What is a downside for me is the massive chunky power/traffic cable that has to be plugged in to use the traffic.
BAVC10
PostPosted: Mon Sep 02, 2013 4:28 pm    Post subject: Reply with quote
You can add as many POIs as you wish for display on the screen - you can select these by enabling layers on your route and add an icon in the Where To screen so that Personal or Favourite icons can be easily selected.
You can add cars as well but have to copy these to the Nuvi's internal drive. The easiest way is the Garmin Garage (Garmin's own site) which will give you an idea of what there is or alternatively go to www.vehiclesforgarminnuvi.com and you will be 100s there.
Page 6 of 22
23.054 (28 May 25)
