Pocket GPS World :: View topic - navi 600
navi 600
hil9279
PostPosted: Tue Jun 18, 2013 12:31 pm    Post subject: navi 600 Reply with quote
Hi im trying to install speed camera data base to my navi 600 Vauxhall. it say its supported but doesn't tell me how to install .Tried downloading and unzipping files . I have put them onto a pen .tried installing it onto the navi 600 but is just keeps saying no points of interests availably. any ideas please keep in mind I am a complete novice cheers Very Happy
PostPosted: Tue Jun 18, 2013 1:07 pm    Post subject: Reply with quote
Moved to Speed Can forum - might get more help there...
"Settling in nicely" ;-)
James12
PostPosted: Wed Jul 03, 2013 7:20 pm    Post subject: Reply with quote
Does the new installation guide (what I wrote) at http://www.pocketgpsworld.com/uksafetycameras-vauxhall-opel-navi.php help?
Let me know if you have any queries/issues/suggestions. Smile
hil9279
PostPosted: Wed Jul 03, 2013 7:58 pm    Post subject: Reply with quote
Thanks for your
Tried everything but it comes up with points of interest failed .Any ideas
Cheers Wayne
James12
PostPosted: Wed Jul 03, 2013 8:19 pm    Post subject: Reply with quote
Where during the import process is it failing exactly? Based on my experience, it will fail at or under 50% if it can't find/read the file from the USB flash drive, and at 51-99% if it isn't happy with the contents of the file (it tells you the number of the line it doesn't like).
hil9279
PostPosted: Wed Jul 03, 2013 8:36 pm    Post subject: Reply with quote
its failing before it even start with a %
it says this might take some time then fails straight away
James12
PostPosted: Wed Jul 03, 2013 8:47 pm    Post subject: Reply with quote
If you haven't already done so, put an MP3 file on the root file of the USB flash drive. The Navi should automatically find and play the file if you insert the drive into the USB socket when the Navi is switched on.
If the Navi can find and play the file then it's happy with the drive you are using and the format on it. If it can't, then the issue may lie with the drive and/or the file format on it.
hil9279
PostPosted: Wed Jul 03, 2013 8:54 pm    Post subject: Reply with quote
Just tried that music file is working ok .I appreciate your time going on a long journey and really need this
James12
PostPosted: Wed Jul 03, 2013 9:09 pm    Post subject: Reply with quote
I think we can assume that the Navi is OK with the USB flash drive then.
Perhaps as a next step, I can send you a file to put on the drive in case that's where in the process it's going wrong.
If you want to try this, let me know (a) which country you want, (b) if you want unconfirmed speed cameras or not, and (c) where I can send the file to.
I can't really think of anything else I can do unless you happen to live really close to me but let me know if you have any thoughts. Smile
hil9279
PostPosted: Wed Jul 03, 2013 9:15 pm    Post subject: Reply with quote
Yes that would be great I live in south wales not sure where you are .I will leave the camera part to you what do think is the best . The country uk
you can send it to .Just another question what format is it in word or exel ?
Cheers James
James12
PostPosted: Wed Jul 03, 2013 9:38 pm    Post subject: Reply with quote
Email sent...
Fingers crossed.
PostPosted: Wed Jul 03, 2013 10:15 pm    Post subject: Reply with quote
@hil9279.
It's not a good idea to put your email on any forum without disguising it as it invites spam. As James12 now has your address it might be a good idea to edit your post and delete the email address. Or you could use the private message system which is a little less insecure.
hil9279
PostPosted: Wed Jul 03, 2013 10:16 pm    Post subject: Reply with quote
Cheers for that .Just deleted it
James12
PostPosted: Wed Jul 03, 2013 11:00 pm    Post subject: Reply with quote
Apologies from me for not pointing out that email addresses shouldn't be put in posts but should ideally be sent via PM Embarassed
Anyway, the file is uploaded successfully to the Navi 600 now so mission accomplished. Smile
vdubuk
PostPosted: Fri Sep 20, 2013 4:05 pm    Post subject: Reply with quote
Im having similar issues trying to upload the Speed camera POI's to my Navi 600.
i followed the guide at http://www.pocketgpsworld.com/uksafetycameras-vauxhall-opel-navi.php
I am using a 1GB usb thumb drive.
I formatted it as FAT32 (I also tried as standard FAT and had the same problem)
Created a folder called MyPOIs and copied on to the thumb drive pocketgps_uk_masters_and_pmobile_5
When I tried to upload it into the Navi 600 i received the follow error on the display
Import failure in line 0
File: pocketgps_uk_masters_and_pmobile_5.poi
Please check the user manual.
When I tried uploading the pocketgps_uk_sc_5 file it went to 50% within a few second and didnt go any further.
I put an MP3 on to the root of the Thumb drive which played fine
22.094 (25 Sep 24)
