Revlew Occasional Visitor
Posted: Fri Jun 21, 2013 9:27 am Post subject: New Nuvi 2548 |
Hi, Just bought a Nuvi 2548 after about ten years of using a TT navigator, which has just finally failed.
Not sure if I like the format of the 2548 as it is so different to TT, but it appears there is not a user manual at the moment which is not helpful.
Being of the 'wrinkly' age group is there anyone out there to enlighten me, is it possible to download maps and camera details from this site or does everything have to go through the Garmin site and their Garmin Express software. Also about POI's have these to be of the 'Garmin' set etc.
I see comments about POI loaders etc, but are these universal or for specific models.
This model has western Europe map installed, is it possible to just have a UK only map added??
Yes I have many questions to work out so any help would be greatly appreciated.
Revlew |
BAVC10 Lifetime Member
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Posted: Fri Jun 21, 2013 10:28 am Post subject: |
Hi - I am sure you will enjoy your Garmin.
Yes your POI's need to be for the Garmin format - there are some converters available though.
Probably best to install Garmin Express and let the system make a back-up of the main files - many of us take a full system back-up but there are some hidden files so reply if you want to do this. Garmin Express will then alert you to the updates - there are some British Voice updates and a firmware update you should install. Garmin Express also has an option to find the link to the manual (these don't come in the box) - as it is a new model unit you may have to go to Garmin's product page.
You can just have UK maps if you want - easiest way is to wait until the 2014.10 maps - any day now (from Garmin not this site) come out (your unit should have 2013.41 installed). The maps are updated 4 times per year and either Garmin Express or Garmin's Mapupdater will alert you to their availability and allow you to select specific regions. If you have all of Europe you can select UK&Eire only option if you want (this will overwrite and replace the existing maps leaving you just with Europe) or you can also include Benelux as well or just Western Europe if you have no need for Eastern Europe. I'd just keep the full set - over time, as the maps increase in file size you may need to select a more region specific map set.
Garmin POI loader is generic to the Garmin / Garmin Nuvi range so head to Garmin's webpages and download the latest version.
If you use ASH10's Camera Manager there is an option just below Garmin POI Loader to select a version which works with this.
Hope this helps _________________ DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
sussamb Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
Joined: Mar 18, 2011 Posts: 4458 Location: West Sussex
Posted: Fri Jun 21, 2013 11:04 am Post subject: |
Adding to that helpful reply.
You can't 'add' a UK map as it's included in Western Europe. You could as explained replace Western Europe with a UK only map but there is really no benefit in doing so.
Manual is here http://static.garmincdn.com/pumac/nuvi_24x7_25x7_OM_EN.pdf
I would definitely back up your nuvi, it's really one of the first things you should do then if anything goes wrong you'll have all the necessary files. As already explained, many of the files are contained in a hidden .system folder. You'll need to set Windows Explorer to show hidden and system files:
![](http://i1098.photobucket.com/albums/g364/sussamb/Capture-1_zpsf784a70f.jpg) |
Posted: Fri Jun 21, 2013 4:21 pm Post subject: Re Nuvi 2548 |
To BAVC10 & SUSSAMB, many many thanks for your reply.
One further question if I may...is there any benefit in using this site's camera data over that which Garmin put out; how often does Garmin update it's camera data??
Thanks again
Revlew |
Posted: Fri Jun 21, 2013 10:36 pm Post subject: |
Suggest you use this site's cameras which are updated weekly and tend to be far more accurate than Garmin's which are provided by Cyclops.
If you want to take the month Free Trial I would wait a few months as the new Nuvis come with April 2013 data so is quite up-to-date anyway. _________________ DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 493 Location: South Yorkshire
Posted: Sun Jun 23, 2013 12:39 am Post subject: |
Now it might be different for the non-live versions but for live models (2390) then updates never really appeared on a daily basis. Cameras were always out of date.
I fully rely on PGPSW cameras now for speed camera notification as the oldest it is ever out of date is one week and not months like Garmin's can be. |
Posted: Sun Jun 23, 2013 7:03 pm Post subject: Re Nuvi 2548 |
Hi Guys
Thank you all for the responses.
Now just got to get my head around the Camera Manager & the POI loader.
Without question the heart of Pocket GPS World is it's member.
Thanks again
Revlew |
