Mahame Occasional Visitor
Posted: Mon May 20, 2013 2:11 pm Post subject: "On startup also run" - failing |
I am running CameraAlert V1.3.10.765 on Samsung S2 and also Nexus 7 tablet and both work great
I have CamerAlert configured to run my SatNav app (Sygic) on startup and for some reason this stopped working on the Nexus 7 and I have to manually start Sygic. I have uninstalled and re-installed both Sygic and CameraAlert. I have also tried starting other apps from the CameraAlert "On startup also run" option and none start when launching CamersaAlert
Has anyone any ideas ? is "Show diagnostics" of any use ? - how and where could I submit a diagnotic report ?
HammY |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
Posted: Mon May 20, 2013 4:54 pm Post subject: |
Dark blue Tabs at the top of the page, click the one called Support.
Submit the support ticket that way including any logs you have.
gets picked up and dealt with quickly.
Having said that though, you'll probably get a reply to this post from one of the Staff as well. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
lbendlin Pocket GPS Staff
Posted: Mon May 20, 2013 6:48 pm Post subject: |
Does it still work on the S2? Are they on the same Android version? Did you modify any of the developer options? (There are a few that might impact this)
Would you be willing to install an app that can look at the log? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Tue May 21, 2013 2:24 pm Post subject: |
lbendlin wrote: | Does it still work on the S2? Are they on the same Android version? Did you modify any of the developer options? (There are a few that might impact this)
Would you be willing to install an app that can look at the log? |
Lutz,
Yes it has always worked on S2 and previously worked on Nexus7. S2 is Android 4.0.4 and Nexus7 is 4.2.2. I am unsure if it stopped working after an o/s update.
I am happy to run an app to run and app and to supply any logs/info etc.
Thanks,
HammY |
Posted: Thu May 23, 2013 7:03 pm Post subject: |
it's called "alogcat" and is available from the google play store. You would run alogcat, put it in the background, run CamerAlert (and observe the issue) then bring alogcat to the front again and save the captured log (and ideally send it to us) _________________ Lutz
