Pocket GPS World :: View topic - Route planner advice needed
capers
PostPosted: Tue Apr 30, 2013 5:55 pm    Post subject: Route planner advice needed Reply with quote
Hello all,
I have a Garmin Nuvi 1490 and manage the maps / data / routes etc via either Map Source or Base Camp, but ...
I have been told of a route planner that will allow me to plan a route, amend it by dragging the route and then being able to save it to my SatNav.
Does anyone have any idea of the name of the 'manner from heaven'?
Thanks.
Kritou
PostPosted: Tue Apr 30, 2013 8:43 pm    Post subject: Reply with quote
AFAIK whatever app or program you create a route with you will still have to use Mapsource or Basecamp to transfer it to your Garmin
capers
PostPosted: Tue Apr 30, 2013 8:49 pm    Post subject: Reply with quote
Thanks for your reply.
Have no problem transferring routes via basecamp etc, my problem is creating routes by dragging the planned route to suit my needs.
PostPosted: Wed May 01, 2013 6:31 am    Post subject: Reply with quote
You can drag routes in Basecamp ...
I do it all the time to load routes to my 1490 or Etrex 20 Smile
Try this. Select the route, then select the insert tool and hover it between the start and end points until you see a rather thick black line appear between the start and finish point. Left click the mouse and release. You'll now be able to drag the line to where you want and then left click. The route will now be recalculated using where you clicked as a via point. Add more points as required. Right click when you've finished to exit.
capers
PostPosted: Wed May 01, 2013 9:28 pm    Post subject: Reply with quote
I've tried this - its not quiet so simple, but I did manage to sort out my route - Thank you SUSSAMB
23.054 (28 May 25)
