Pocket GPS World :: View topic - GO920T battery replacement
Hectorsgaf
PostPosted: Wed Apr 17, 2013 3:26 pm    Post subject: GO920T battery replacement Reply with quote
Had a good look through the threads on here re battery replacement but they are getting a bit old now hence 2 questions -
Is there a current tried and tested / recommended extended life battery now or do I stick with a straight 1300mah replacement and .....
Is there a recommended source for these? Amazon etc list from £6.99 to £20 but batteries all look the same to me just that some may come with vids and tools which I already have. Just don't want a dud ( ish ) battery being sent.
Thank you.
PostPosted: Fri Apr 19, 2013 12:48 pm    Post subject: Reply with quote
I'd stick with a one-for-one 1300mA replacement.... just in case anything more stresses the charging circuitry.
As for price, do it like getting tradesmen? Don't pick the cheapest or most expensive, but choose one you like the sound of in the middle? Laughing
"Settling in nicely" ;-)
Pocketgps
PostPosted: Tue Apr 23, 2013 8:27 pm    Post subject: Reply with quote
I've used this seller below for a TT One v4 and TT go520 batts. Both are working fine after several months since I fitted them.
http://www.ebay.co.uk/itm/1300mAh-Battery-For-TomTom-Go-920-Go-920T-Go-XL330-Go-XL330S-/150974318144?pt=UK_In_Car_Technology&hash=item2326c54640
Edit: Delivery took about 5 days.
Hectorsgaf
PostPosted: Wed Apr 24, 2013 9:22 am    Post subject: Reply with quote
Had already ordered from MDSbattery.co.uk but thank you any way.
Must say, delivery was pretty damn quick.
Following no little amount of tentativeness and more than a little shaking of my poor old hands new battery now fitted. Pretty easy really. Didn't need to disconnect the ribbon etc. magnetic torx helped no end. Levering out the old battery is certainly not a job for the faint hearted but I got there in the end. hair dryer didn't seem to help much.
Trusty old 920 is now holding a charge like new and more importantly the thing still works!! Shocked I must try and look after this battery - run it down regularly etc and not just throw it in the drawer to discharge.
matthewj
PostPosted: Wed Apr 24, 2013 9:50 am    Post subject: Reply with quote
If it is like the one in the ebay picture, you should keep it charged up, as they like it better that way. NiCd was the type that needed discharging, the new ones are best kept charged. (If you are able to get them to about 60% charge and then not have any power drain, that's best for long term storage, but otherwise just keep it topped up.)
Hectorsgaf
PostPosted: Wed Apr 24, 2013 9:55 am    Post subject: Reply with quote
Understood. Thank you for that. No probs then just leaving it in cradle charging on computer when not being used?
This is the one I got
http://www.mdsbattery.co.uk/shop/productprofile.asp?ProductGroupID=2741
matthewj
PostPosted: Wed Apr 24, 2013 2:39 pm    Post subject: Reply with quote
Cradle is fine - I wish I could do that with mine...
