Pocket GPS World :: View topic - Need a TomTom Bluetooth External Antenna
ssar
PostPosted: Fri Sep 10, 2004 6:38 pm    Post subject: Need a TomTom Bluetooth External Antenna Reply with quote
Hi, Does anyone know where I can get an external antenna for my TomTom bluetooth receiver?
Thanks.
MrT
PostPosted: Fri Sep 10, 2004 7:04 pm    Post subject: Reply with quote
You should get a re-radiating antenna such as:
http://www.globalpositioningsystems.co.uk/search.php?search=re-radiating&x=17&y=10
This does not require connection the the BT unit so it helps keep it portable.
ssar
PostPosted: Fri Sep 10, 2004 7:28 pm    Post subject: Any hardwired antennas? Reply with quote
The re-rediateing antenna looks good, but I would prefer a hardwired solution. Do you know of any?
Thanks.
MrT
PostPosted: Fri Sep 10, 2004 8:01 pm    Post subject: Reply with quote
Why get a wirefree unit then hardwire it, you might have well have bought the hardwired GPS unit?
MrT
PostPosted: Fri Sep 10, 2004 8:05 pm    Post subject: Reply with quote
THere was a discussion on this a while back and someone named an antenna that would fit, but it was not from TomTom. You may be able to find it in a search of this forum.
a4ace
PostPosted: Fri Sep 10, 2004 9:56 pm    Post subject: Reply with quote
you can get this instead...
http://www.pocketgpsworld.com/deluo-black-box.php
if you have the tomtom bluetooth cradle, you can hardwire the cradle in the parcel shelf like what i did.
or you can wire a cig lighter plug to hardwire the re-rad.
tomtom 940 live/tt active dock holder/tt rds-tmc traffic receiver usb
PostPosted: Fri Sep 10, 2004 10:11 pm    Post subject: Reply with quote
A quick search found one at GPS4Less
"WAAH03RIK External Antenna for Bluetooth GPS Receiver/Antenna Magnetic base antenna for Tom Tom Blue Tooth receiver, MMCX connector for use when the BT Receiver is impaired by Windscreen inserts. £29.95 inc vat."
Scotes
PostPosted: Sat Sep 11, 2004 10:57 pm    Post subject: Reply with quote
Post back if you happen to be in the US. I have the distributor info (not handy at the moment) on who carries an external antenna that fits the bluetooth unit. It was a pain to find.
As to why use it? I have my bt unit hard wired in the trunk and the antenna significantly helps in the signal reception.
ssar
PostPosted: Sun Sep 12, 2004 5:02 pm    Post subject: Distributor in the USA Reply with quote
Yes, I'm located in the USA. A US based company would be great!.
Thanks.
STe
22.063 (19 Jun 24)
