sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Tue Dec 18, 2012 1:47 pm Post subject: |
Fraid you're correct. current.gpx is simply a one way copy of what is stored in inaccessible memory. You could even delete it and your nuvi will simply recreate it again when it boots. As well as tracks, it contains any saved routes, favourites etc. |
Kremmen Pocket GPS Verifier
Posted: Wed Dec 19, 2012 8:41 am Post subject: |
I think I have a hit ................
There is a GPX\Archive folder that contains a load of x.GPX files. Mine goes from 1 to 12.
I've performed a search and I've found the same data in the Current.GPX file in one of these archives.
I assume that when you boot up, all data from any x.GPX files gets copied to the Current .GPX file
Next stage is to separate the Trip Log data from the favourites data so the Trip Log stuff can be removed.
I've looked further and I think the procedure is to leave all the Metadata and waypoint data behind but remove all the Track data which is within the trk /trk tags.
Failed
Even with no Archive files and with a base Current.GPX it still retrieves the Trip Log data from somewhere! _________________ Satnav:
Car Average MPG :
Posted: Wed Dec 19, 2012 11:21 am Post subject: |
Yep ... fraid it does
I see you've posted on the Garmin forum site ... be interesting to see any response |
Posted: Wed Dec 19, 2012 3:52 pm Post subject: |
Yes, I spotted you were logged on when I posted.
I'm not sure anyone influential reads it but you never know.
I just can't understand the logic of it recording everywhere you go since you bought the unit with no easy way of resetting it! _________________ Satnav:
Car Average MPG :
Posted: Wed Dec 19, 2012 4:49 pm Post subject: |
One theory is that Garmin hoover the files when you connect your GPS and use the data in some way, maybe to influence things like traffic trends etc.
As for whether anyone influential will read it, that depends on the forum. I know for example that the Basecamp developers are active on the Basecamp forums, they've acted/helped with some of my suggestions as well as helping many others. Never seen anyone there from the hardware side though, so your plea may fall on deaf ears |
Posted: Fri Mar 08, 2013 10:10 am Post subject: |
Garmin have just issued a software update for the 30/40/50 ... unfortunately nothing about being able to clear trip log |
Posted: Fri Mar 08, 2013 1:15 pm Post subject: |
Must take mine indoors tomorrow and plug it in _________________ Satnav:
Car Average MPG :
Posted: Thu Apr 04, 2013 7:06 am Post subject: |
No mention of re-setting the trip log
I note they have found some issue with multiple icons. This must be what some of the error reports here were about. Never had an issue myself.
I'm now running the TomTom 24x24's from here with the red backgrounds. _________________ Satnav:
Car Average MPG :
