TartanGiant Occasional Visitor
Posted: Thu Sep 09, 2004 12:34 pm Post subject: Got the case now |
Hi WWG,
No worries - I have just received my carry-case too.
I've yet to install the latest software version into my box of tricks - which has not been performing too well on the A272. False instructions, and dropping signals (despite the re-rad). My rating for the machine has therefore levelled out and I'm not that well pleased. Might have been a bad day for it or something, but it's far from switch on a go.
Nothing is better than the human, but machines are meant to help, not get you peed off with them.
TG |
MrRubberGloves Regular Visitor
![](modules/Forums/images/avatars/7402845004294818d29214.jpg)
Joined: May 09, 2004 Posts: 163 Location: Blackpool, England.
Posted: Thu Sep 09, 2004 3:55 pm Post subject: |
sifi wrote: | When you said "via" in your first post I thought you meant the "travel via" option not the "alternative route" option.
Mine does the same as yours so between us we have found out two unlikely outcomes. |
Sorry about that, my mistake.
sifi wrote: | Maybe your obsevation is due to it using the "current location" as shown at the bottom of the TT screen i.e. your address at Blackpool. This could be because when you tap "done" to enter the options screen of alternative route the screen goes to your last gps signal position map which is most probably your home address, and then uses that as the new starting point. |
It does, do you or anyone know how to get around this?
All I want to do is plan a route from A to B, see what route is planned by TT Go and then set an alternative route but all it does is plan the route using my current location. |
sifi Regular Visitor
Joined: Nov 19, 2003 Posts: 125 Location: Lincolnshire
Posted: Thu Sep 09, 2004 4:24 pm Post subject: |
b]MrRubberGloves wrote about planning with a via or alternative point:[[/b] Quote: | All I want to do is plan a route from A to B, see what route is planned by TT Go and then set an alternative route but all it does is plan the route using my current location. |
I e-mailed TT when you discovered the problem and have not had a reply as yet. Maybe there is not a way around this. I tried changing my home address to a proposed starting point but it does the same. I'll erport their reply when it comes. |
Posted: Thu Sep 09, 2004 4:41 pm Post subject: |
sifi wrote: | All I want to do is plan a route from A to B, see what route is planned by TT Go and then set an alternative route but all it does is plan the route using my current location. |
I e-mailed TT when you discovered the problem and have not had a reply as yet. Maybe there is not a way around this. I tried changing my home address to a proposed starting point but it does the same. I'll erport their reply when it comes.[/quote]
Nice one, thanks for that.
It's probably a glitch. |
wez99 Regular Visitor
![](modules/Forums/images/avatars/187705837742efd27cf1908.jpg)
Posted: Thu Sep 09, 2004 10:04 pm Post subject: |
After some research I have downloaded and installed the speed camera locations. It is quite simple and appears to be accurate and up to date.
I too have recieved my little bag today.
The warning sounds are a bit lame. |
Posted: Thu Sep 09, 2004 10:49 pm Post subject: Speed camera download |
Hello wezZ99,
I am not one to let others do the donkey work, but would you care to offer your expertise as to where/how you managed to download these speed camera locations and insert them into the TTG machine?
The simpler the explanation the more the appreciation for your efforts wez99.
Hope you don't mind me asking.
TG
PS: I'm in a bit of a pickle right now - I cannot find my USB lead to even start transferring version 4.4 so I've time to assimilate your speed camera information - should you be kind enough to tell. |
Posted: Thu Sep 09, 2004 11:05 pm Post subject: |
It's here, or if it's not the right one, have a butchers on here |
Posted: Thu Sep 09, 2004 11:47 pm Post subject: Thanks Mr RubberGloves |
Thanks Mr RubberGloves,
Before I download/insert the wrong thing for TTG, which of these is the correct one for TTG please ?
TomTom
Navigator 1
CheckPOInt - [Instructions]
GPS Assist (Pocket PC 2002 Only) - [Instructions]
POI-Warner - [Instructions]
Navigator 2
Current Database Version: v2.091
Database Last Updated: 01st September 2004
Download the current database here
Once you have downloaded the correct data base for these speed... err Safety Cameras......... is it simple enough to tranfer/input the data to TTG?
The instructions look a bit deep and testing....... Please note that his means you will have to disable the old POI in TomTom Navigator 1 / 2 / 3 and your POI Notification software and re-add the new ones. Or is that info N/A for TTG?
Sorry to be a bit slow on this.............. I'm getting old!!
TG |
Posted: Thu Sep 09, 2004 11:58 pm Post subject: |
On the page where you have got that text from there is a line which says "DOWNLOAD THE CURRENT DATABASE HERE", just click that link and you're away. |
tomcat76 Lifetime Member
![](modules/Forums/images/avatars/205336023041389fc2c8555.jpg)
Joined: Aug 18, 2004 Posts: 100 Location: West London
Posted: Fri Sep 10, 2004 10:47 am Post subject: Re: v4.40 upgrade TTG |
WongWongGo wrote: | Hi TartanGiant:
To be quite honest I did not get any email from TomTom (I registered the day I bought TTG) I find PocketGPS forums much more helpful; which is also where I got the news of the 4.40 upgrade last night.
Same here, and the forums are brill...
Well I hope you guys recieve them this week. I for one was fed up with putting my TTG in an old sock! :wink
Specially if you happen to be wearing it at the time ![Laughing](modules/Forums/images/smiles/icon_lol.gif) _________________ Regards Steve :-) |
Posted: Fri Sep 10, 2004 10:50 am Post subject: Re: v4.40 upgrade TTG |
WongWongGo wrote: | Oh forgot to mention:
I have an Arkon Screen Protector on my TTG (It is very good at reducing reflection and screen smudge protection) but I mentioned before that it does dulls the screen slightly.
I used the original screen protector that came on the ttg, took it off, trimmed it down to fit... will protect the screen for a while... _________________ Regards Steve :-) |
Posted: Fri Sep 10, 2004 11:13 am Post subject: Re: Speed camera download |
TartanGiant wrote: | Hello wezZ99,
There is a detailed 'how to' http://pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=10469&postdays=0&postorder=asc&start=60
Complete with images.... _________________ Regards Steve :-) |
Posted: Fri Sep 10, 2004 11:19 am Post subject: Thanks Steve |
Hi Steve,
Thanks a million :D ..... this will help me a lot.
I need words and pictures .. ha ha
TG |
Posted: Fri Sep 10, 2004 6:27 pm Post subject: |
Hello Tartan
I too followed the link with the pictures on it, and if I can do it anyone can.
Gonna test it out tomorow on my way to work ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
WongWongGo Occasional Visitor
![](modules/Forums/images/avatars/gallery/kanji_for_peace.jpg)
Posted: Fri Sep 10, 2004 7:05 pm Post subject: Old Sock |
Hi Steve:
Yep; like all things computers (Microshaft!) I get the best anwsers from good forums.
p.s. So that was why my sock kept telling me to do a U Turn ! :P |
