Pocket GPS World :: View topic - EUR speedcams on Sygic
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps
PostPosted: Tue Mar 05, 2013 11:42 am    Post subject: EUR speedcams on Sygic Reply with quote
At present I import the PGPSW cam database into Sygic so that I have the mobiles and SPECS showing on the Sygic map and run CA in the background for the alerts. That works just fine and dandy for the UK cams.
Having recently treated myself to twenty five quids worth of Western Europe maps, I tried inporting the PGPSW EUR cams. This failed wit an error message something along the lines of "Import Failed" Sad
I think that Sygic requires that POI (cam) imports are done by country. Has anyone had any experience of this? Can what I want to do be done? If so, how?
PostPosted: Tue Mar 05, 2013 1:03 pm    Post subject: Reply with quote
It'd need a total re-write of the download system to split the download into files by individual country. For the number of Sygic users it's not something high on our priorities for that amount of reworking.
Perhaps I could add the country code (2 or 3 letters) to the download and this could then be filtered in Excel or similar to grab the countries you need for converting? Would that be beneficial?
PostPosted: Tue Mar 05, 2013 3:43 pm    Post subject: Reply with quote
It certainly would MaFt. I still am not sure whether several files can be done at the same time, or even one after the other. What I'll do is sort out a few French cams from the EU download, rupi them and see what Sygic makes of that. I wouldn't want you do anything until I have found out whether it works or not so as not to waste your time (unless you already know the answer). I'll have a go at it in a bit and report back.
The original quuestion was a general one to see if anybody had managed it without too much faffing.
PostPosted: Mon Mar 11, 2013 2:23 pm    Post subject: Reply with quote
Well, it's sort of yes and no. If you just try rupi'ing the data and then importing it it starts importing ok putting the cams in the correct country then fails with an error. The problem seems to be that there seems to be a limit of eight countries allowed, but I'm not sure as I havn't yet been able to prove my theory as I am waiting for MaFt to do the 'country code' thing that he kindly offered to do above. If I can split up the cams by country, then I can continue with my experiments. I will certainly post here again when I have further info.
srobson
PostPosted: Thu Aug 13, 2015 12:02 am    Post subject: Reply with quote
Anyone found a solution for this yet.
Steve
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps All times are GMT + 1 Hour
