nibor Lifetime Member
Posted: Sat Mar 02, 2013 8:49 pm Post subject: New Maps please help |
I have a 1005 I have just installed the new map and it now it says it can not use this map. This is the wrong map for this device is there a way to roll it back? |
dhn Frequent Visitor
Posted: Sat Mar 02, 2013 8:54 pm Post subject: |
What app is installed on your device?
Settings/Me and my device/about my device. _________________ David |
Posted: Sat Mar 02, 2013 9:21 pm Post subject: |
I cant check now. I had a look at tomtom forums and it's not just me, I will try the UK map see if that work as I also have it on my account. |
wilfuerdo Occasional Visitor
Joined: Mar 18, 2007 Posts: 21 Location: South Yorkshire
Posted: Sat Mar 02, 2013 10:55 pm Post subject: |
Hi, I have just had same troubles and managed a fix. please see my earlier post.
Basically what I did:
connected to computer, hold power button until it restarts with drums, keep held in until black configuration screen appears
next, press power button 3 times (fast, within a second)
A cog will appear, then some folder, computer screen etc..
leave this on, connected to mytomtom, it will no doubt suggest reinstall of main software. I did this but it did not help....
do the same process again, and it deleted the map, mytomtom asked me to install software and map.
hope this helps, if you had same issue as I did
good luck
Andy |
Posted: Sat Mar 02, 2013 11:03 pm Post subject: |
Yes, I have done this and it works as long as I only install UK and NI which I still have on this account but I bought a new device with life time Europe maps that don’t work, It's as if the Europe map is corrupted in some way.
Posted: Sat Mar 02, 2013 11:21 pm Post subject: |
my device is new with life time updates, but I only have Europe maps on there.
Once I had done this procedure it failed to download & install Europe map twice, third time it worked for me.
hope you get help, so annoying this mytomtom vs the tom tom home I used to use, able to physically see the files. |
