Pocket GPS World :: View topic - TT3 for Benelux with French names!
black_cabbie
PostPosted: Thu Sep 09, 2004 10:47 am    Post subject: TT3 for Benelux with French names! Reply with quote
I have the CD for benelux. When I do the installation, I am not asked if I want french or dutch names for the maps. it installs Dutch names.
What am I doing wrong?
George
joejoe123
PostPosted: Thu Sep 09, 2004 8:34 pm    Post subject: Reply with quote
I guess map names are decided by tomtom but if you want to change the map names do the following.
if you want to change the benelux map name go to file explorer and navigate to your storage card , open the benelux folder and there will be 2 files called "Benelux" , press and hold and then rename the file to anything you want but both files must have the same name, otherwise tomtom will not find the maps.
try it at your own risk , if you have any troubles just rename them back to the original name.
black_cabbie
PostPosted: Fri Sep 10, 2004 7:04 am    Post subject: Reply with quote
Thanks for the reply.
Could it be that there is a french road version and a Dutch? Because I've tried anything and still the name of the roads appear in Dutch!
kartracer
PostPosted: Fri Sep 10, 2004 9:01 am    Post subject: Reply with quote
black_cabbie,
I don't have TT3 but I know that on TT2 EuroMaps there are both French and Dutch versions of the Benelux maps on CD1. You have to load the correct version off the CD.
Kam
black_cabbie
PostPosted: Fri Sep 10, 2004 11:32 am    Post subject: Reply with quote
On TT2 during the installation you were prompted to either install french or dutch names. On TT3 it installs Dutch no matter what you do. I was hoping there was a french version but so far I haven't been able to find a solution. Maybe I have to send a mail to Tomtom support.
joejoe123
PostPosted: Fri Sep 10, 2004 3:39 pm    Post subject: Reply with quote
i do not think you can change the names of the roads , names are names ,
if you are in france you have french names and in germany you have german names.
if you have an address from The netherlands ,sure you have it in dutch.
andrewh
PostPosted: Mon Sep 13, 2004 11:49 am    Post subject: Reply with quote
It is very simple but you need to know. If you choose French names then it will use French names in Bruxelles. If you choose Dutch names then it will use Dutch names in Brussel.
Bruseels is officially a bi-lingual city so both map sets are required as all names are gicn in both languages on paper maps. It would take too much space to do this on Tomtom.
HTH
Andrew
TonyP
PostPosted: Tue Sep 14, 2004 7:38 pm    Post subject: Reply with quote
HTH
Andrew
But how do you do this in V3? In V2 it offered the choice, but I get the Dutch names in V3 as well.
The problem is that although Brussels is officially bilingual, everyone invariably uses the French street names, and it is not easy to guess what the Dutch version is, even if you speak Dutch.
andrewh
PostPosted: Wed Sep 15, 2004 11:26 am    Post subject: Reply with quote
I use the Palm version where both are on the CD and I had to choose before loading to a card.
Certainly difficult to work out Brussels names from one langauge to another!
Andrew
TonyP
PostPosted: Wed Sep 15, 2004 11:48 am    Post subject: Reply with quote
OK, I've got it!
The Benelux maps are on 2 Cds, CD1 is the dutch names and CD2 is the French names. There is nothing that indicates this, so everyone installs CD1 and gets the Dutch names.
black_cabbie
PostPosted: Mon Oct 04, 2004 6:07 pm    Post subject: Reply with quote
lovely!!! So now I just need to find the 2nd CD of Benelux.....
