Pocket GPS World :: View topic - CamerAlert keeps quitting with iOS6.1
Goto page Previous  1, 2, 3, 4, 5  Next
CA_0216224501
PostPosted: Sun Feb 03, 2013 12:48 pm    Post subject: Similar but different Reply with quote
GPS_fan wrote:
Unfortunately, bathbadger appears to be correct - CamerAlert is stable whilst static but crashes on the move.
6 crashes within 15 minutes this morning
Iphone5 updated ioS 6.1 works fine then goes to standby mode but will work fine with no probs if I'm listening to an audio book whilst driving ???????
PostPosted: Sun Feb 03, 2013 1:18 pm    Post subject: Reply with quote
Do you have 'Prevent Standby' enabled in settings?
GPS_fan
PostPosted: Sun Feb 03, 2013 1:44 pm    Post subject: Reply with quote
Yes
Andy
PostPosted: Sun Feb 03, 2013 3:38 pm    Post subject: Reply with quote
GPS_fan wrote:
Yes
Sorry Andy, that was intended for "CA_0216224501" in the previous post.
simont56
PostPosted: Mon Feb 04, 2013 1:00 pm    Post subject: Crash Logs Reply with quote
MaFt wrote:
Crash logs do eventually filter back through to us via Apple but to speed things up can you locate them and send us them?
Can you send them to us at team AT pocketgpsworld.com
Am also suffering same problems.
Just checked my crash logs and it would appear that the crashes are listed as 'LowMemory' rather than CameraAlert. Not sure whether this helps.
Am running iPhone 4, updated with iOS 6.1, fully restored post upgrade and Camera Alert app deleted and re-installed with no change in performance.
Simon
PostPosted: Tue Feb 05, 2013 12:20 am    Post subject: Reply with quote
Thanks Simon. I was beginning to have my suspicions that it was a memory issue as the iPhone 4 is the oldest device with Retina screen that runs iOS 6.1...
GPS_fan
PostPosted: Fri Feb 08, 2013 7:27 am    Post subject: Reply with quote
In map settings, if you change from 'Always' to 'Near Camera', it seems to improve stability.
Unfortunately, my journey is too short to thoroughly test, but CamerAlert did not quit at all this morning when it would otherwise have quit at least 5 times.
Andy
PostPosted: Fri Feb 08, 2013 8:27 am    Post subject: Reply with quote
As it appears to be an issue caused by the vector maps gobbling up memory in 6.1, you may find that switching off the maps stops the crashing completely.
I know this isn't a long term solution but it might at least allow you to use the app, without it crashing, in the interim whilst we research a fix.
GPS_fan
PostPosted: Fri Feb 08, 2013 8:36 am    Post subject: Reply with quote
...if maps are turned off completely, would you still get your average speed displayed in an average speed camera zone?
Andy
PostPosted: Fri Feb 08, 2013 8:37 am    Post subject: Reply with quote
Yes Thumbs Up
PostPosted: Fri Feb 08, 2013 10:28 am    Post subject: Reply with quote
Which, again, goes hand in hand with the memory theory - if the maps are only being displayed for a short period (near a camera) then there is less map data being stored in memory and therefore the 'crash' will take longer to occur.
jdp1962
PostPosted: Sun Feb 10, 2013 4:11 pm    Post subject: Reply with quote
I updated to iOS 6.1 this morning, and immediately encountered the problem with Camera Alert shutting down every two minutes or so. I'm just in the middle of a phone restore at present, then will try it with maps always on and with maps only on near camera, see how it behaves and report back.
jdp1962
PostPosted: Mon Feb 11, 2013 9:49 am    Post subject: Reply with quote
Still shuttong down every couple of minutes. Will next try deleting the app, and reinstallnig it from scratch.
GPS_fan
PostPosted: Mon Feb 11, 2013 9:52 am    Post subject: Reply with quote
Try it with maps set to 'Never' - this has improved stability for me.
Andy
PostPosted: Tue Feb 12, 2013 7:30 pm    Post subject: Reply with quote
Even with maps set to "Near camera" you can mitigate the issue for some time. I did some performance analysis with the Xcode tools ("Instruments") and there is definitely something broken with the vector map memory management. It is sufficient to pan and zoom the map around a bit to cause the app to silently terminate - without a crash log. Memory usage can go as high as 250 MB which is especially problematic on low spec devices like the iPhone 4 (not sure how much RAM it has but I seem to remember it was only 512 MB).
Looking in the Apple forums they are certainly aware of the issue but it doesn't look like a fix was included in the latest 6.1.1 version.
Page 3 of 5
