Pocket GPS World :: View topic - REVIEW COMMENTS: TomTom GO
Goto page Previous  1, 2, 3 ... 31, 32, 33, 34, 35  Next
TartanGiant
PostPosted: Thu Sep 09, 2004 12:34 pm    Post subject: Got the case now Reply with quote
Hi WWG,
No worries - I have just received my carry-case too.
I've yet to install the latest software version into my box of tricks - which has not been performing too well on the A272. False instructions, and dropping signals (despite the re-rad). My rating for the machine has therefore levelled out and I'm not that well pleased. Might have been a bad day for it or something, but it's far from switch on a go.
Nothing is better than the human, but machines are meant to help, not get you peed off with them.
TG
MrRubberGloves
PostPosted: Thu Sep 09, 2004 3:55 pm    Post subject: Reply with quote
sifi wrote:
When you said "via" in your first post I thought you meant the "travel via" option not the "alternative route" option.
Mine does the same as yours so between us we have found out two unlikely outcomes.
Sorry about that, my mistake.
sifi wrote:
Maybe your obsevation is due to it using the "current location" as shown at the bottom of the TT screen i.e. your address at Blackpool. This could be because when you tap "done" to enter the options screen of alternative route the screen goes to your last gps signal position map which is most probably your home address, and then uses that as the new starting point.
It does, do you or anyone know how to get around this?
All I want to do is plan a route from A to B, see what route is planned by TT Go and then set an alternative route but all it does is plan the route using my current location.
sifi
PostPosted: Thu Sep 09, 2004 4:24 pm    Post subject: Reply with quote
b]MrRubberGloves wrote about planning with a via or alternative point:[[/b]
I e-mailed TT when you discovered the problem and have not had a reply as yet. Maybe there is not a way around this. I tried changing my home address to a proposed starting point but it does the same. I'll erport their reply when it comes.
MrRubberGloves
PostPosted: Thu Sep 09, 2004 4:41 pm    Post subject: Reply with quote
I e-mailed TT when you discovered the problem and have not had a reply as yet. Maybe there is not a way around this. I tried changing my home address to a proposed starting point but it does the same. I'll erport their reply when it comes.[/quote]
Nice one, thanks for that.
It's probably a glitch.
wez99
PostPosted: Thu Sep 09, 2004 10:04 pm    Post subject: Reply with quote
After some research I have downloaded and installed the speed camera locations. It is quite simple and appears to be accurate and up to date.
I too have recieved my little bag today.
The warning sounds are a bit lame.
TartanGiant
PostPosted: Thu Sep 09, 2004 10:49 pm    Post subject: Speed camera download Reply with quote
Hello wezZ99,
I am not one to let others do the donkey work, but would you care to offer your expertise as to where/how you managed to download these speed camera locations and insert them into the TTG machine?
The simpler the explanation the more the appreciation for your efforts wez99.
Hope you don't mind me asking.
TG
PS: I'm in a bit of a pickle right now - I cannot find my USB lead to even start transferring version 4.4 so I've time to assimilate your speed camera information - should you be kind enough to tell.
MrRubberGloves
PostPosted: Thu Sep 09, 2004 11:05 pm    Post subject: Reply with quote
It's here, or if it's not the right one, have a butchers on here
TartanGiant
PostPosted: Thu Sep 09, 2004 11:47 pm    Post subject: Thanks Mr RubberGloves Reply with quote
Thanks Mr RubberGloves,
Before I download/insert the wrong thing for TTG, which of these is the correct one for TTG please ?
TomTom
Navigator 1
CheckPOInt - [Instructions]
GPS Assist (Pocket PC 2002 Only) - [Instructions]
POI-Warner - [Instructions]
Navigator 2
Current Database Version: v2.091
Database Last Updated: 01st September 2004
Download the current database here
Once you have downloaded the correct data base for these speed... err Safety Cameras......... is it simple enough to tranfer/input the data to TTG?
The instructions look a bit deep and testing....... Please note that his means you will have to disable the old POI in TomTom Navigator 1 / 2 / 3 and your POI Notification software and re-add the new ones. Or is that info N/A for TTG?
Sorry to be a bit slow on this.............. I'm getting old!!
TG
MrRubberGloves
PostPosted: Thu Sep 09, 2004 11:58 pm    Post subject: Reply with quote
On the page where you have got that text from there is a line which says "DOWNLOAD THE CURRENT DATABASE HERE", just click that link and you're away.
tomcat76
PostPosted: Fri Sep 10, 2004 10:47 am    Post subject: Re: v4.40 upgrade TTG Reply with quote
WongWongGo wrote:
Hi TartanGiant:
To be quite honest I did not get any email from TomTom (I registered the day I bought TTG) I find PocketGPS forums much more helpful; which is also where I got the news of the 4.40 upgrade last night.
Same here, and the forums are brill...
WongWongGo wrote:
Hi TartanGiant:
Well I hope you guys recieve them this week. I for one was fed up with putting my TTG in an old sock! :wink
Specially if you happen to be wearing it at the time Laughing Laughing
Regards Steve :-)
tomcat76
PostPosted: Fri Sep 10, 2004 10:50 am    Post subject: Re: v4.40 upgrade TTG Reply with quote
WongWongGo wrote:
Oh forgot to mention:
I have an Arkon Screen Protector on my TTG (It is very good at reducing reflection and screen smudge protection) but I mentioned before that it does dulls the screen slightly.
I used the original screen protector that came on the ttg, took it off, trimmed it down to fit... will protect the screen for a while...
Regards Steve :-)
tomcat76
PostPosted: Fri Sep 10, 2004 11:13 am    Post subject: Re: Speed camera download Reply with quote
TartanGiant wrote:
Hello wezZ99,
There is a detailed 'how to' http://pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=10469&postdays=0&postorder=asc&start=60
Complete with images....
Regards Steve :-)
TartanGiant
PostPosted: Fri Sep 10, 2004 11:19 am    Post subject: Thanks Steve Reply with quote
Hi Steve,
Thanks a million :D ..... this will help me a lot.
I need words and pictures Wink .. ha ha
TG
wez99
PostPosted: Fri Sep 10, 2004 6:27 pm    Post subject: Reply with quote
Hello Tartan
I too followed the link with the pictures on it, and if I can do it anyone can.
Gonna test it out tomorow on my way to work Sad
WongWongGo
PostPosted: Fri Sep 10, 2004 7:05 pm    Post subject: Old Sock Reply with quote
Hi Steve:
Yep; like all things computers (Microshaft!) I get the best anwsers from good forums.
p.s. So that was why my sock kept telling me to do a U Turn ! :P
Page 32 of 35
22.063 (19 Jun 24)
