Pocket GPS World :: View topic - SD card problem
SD card problem
fire-bobby
PostPosted: Mon Dec 31, 2012 8:39 pm    Post subject: SD card problem Reply with quote
Hi, this is my 1st post on the forum and hoping to see if anyone has had the same issue.
I have just bought an Active 10 and SD card for all National Parks 1:50k. When I insert the card, the unit recognises it and a brings up the title "All National Parks". I select this and it brings up the list for all the parks, but when I select a park I just get a pale blue screen on the planning page.
If I zoom out I can see an icon for each of the national parks (circle with a cross in it) at their location relative to a map of the UK, but again there is just a plain pale blue screen in the background.
I hooked up tp SatSYNC this morning and upgraded to the latest software.
Two questions:
1. There is a little yellow slider tab on the SD card, does it matter which position this is in?
2. There is a grey icon of a padlock next to the title "All National Parks" as mentioned earlier, does this mean that the SD card needs unlocking?
I have emailed Tech Support at Satmap yesterday but I am just asking in case anyone can shine any light on the issue?
Thanks for reading. Sad
fire-bobby
Duddy
PostPosted: Mon Dec 31, 2012 9:28 pm    Post subject: Reply with quote
Hi Fire-bobby
I don't know anything about the mapping system you've purchased but regards the SD card.
The small slider is a lock device (I believe to make it read only), with the chamfer on the card in the top right, the card is locked if the slider is down and unlocked if up.
Hope this helps
HUAWEI P30 Pro (new edition) with Speedtrap Alert & alcatel1 for SatNav
CoPilot 10 with CamerAlert
RoadHawk in-car video
Reading glasses getting thicker as is my waist
Retired but want to go back to work for a rest.
JimmyTheHand
PostPosted: Mon Dec 31, 2012 11:06 pm    Post subject: Reply with quote
have you tried moving the cursor into one of the parks and zooming in?
J.
fire-bobby
PostPosted: Tue Jan 01, 2013 12:38 am    Post subject: Reply with quote
Duddy wrote:
Hi Fire-bobby
Hope this helps
Hi Duddy,
Thanks for the information, something new I've learned today.
Fire-bobby
fire-bobby
PostPosted: Tue Jan 01, 2013 12:43 am    Post subject: Reply with quote
Hi J,
Yeah tried that mate - once I had the cursor over the park I zoomed fully in and also fully out, but to no avail.
I'll get in touch with Tech Support by phone on Wednesday and see what they have to say. My gut feeling is that I've got a dud SD card.
Either way I will post a comment on the forum just in case anyone else encounters this problem.
Fire-bobby
AliOnHols
PostPosted: Tue Jan 01, 2013 9:35 am    Post subject: Reply with quote
Hi fire-bobby, this happened to me once, I think I solved it by switching the A10 off with the SD card in, removing the batteries for a minute or two, replacing the batteries, switching the A10 back on, walking outside, leaving it alone for about 10 minutes and when I returned to it, it had sorted itself out.
Like you, I had updated to the latest software versions before performing this "reboot".
Garmin Nuvi 2599
SatMap Active 10 & 20.
fire-bobby
PostPosted: Tue Jan 01, 2013 10:20 pm    Post subject: Reply with quote
Hi Ali,
I will try that in the morning mate and let you know.
Thanks for your input.
fire-bobby
fire-bobby
PostPosted: Wed Jan 02, 2013 12:53 pm    Post subject: Reply with quote
Hi All,
Issue resolved!
I turned the unit on this morning as I was going to follow the procedure that Ali advised, to my surprise the maps appeared straight away.
My assumption is that the SD card was not compatible with the software version that was with the unit that I bought. Once I had upgraded the software via SatSYNC to version 1.5 that appeared to resolve the issue.
When I first upgraded the software the unit still showed version 1.334, now 24 hours later it correctly shows the upgrade to version 1.5.
I hope this helps anyone else who encounters this issue, and may I say thank you for your input and advice to help me out.
Best regards and cheers.
fire-bobby
