wetdogleader Occasional Visitor
Joined: May 03, 2006 Posts: 40 Location: Woodford Green
Posted: Wed Dec 19, 2012 3:46 pm Post subject: Cameralert has stopped working |
I am running your app on a Samsung Galaxy Note 2. Absolutely great when it working but I am suffering with a lot of the above subject especially on Sunday, is it religious? Also having the voice alerts set to long when you come round the M25 past the M26 junction where you are in a 50mph speed limit through the current road works this thing goes of alarming! So much so that after about 10 warnings going through this stretch it drove me mad and I had to turn it off. Sort of defeats the object. I have now set it to short message but if you are below the limit, why all the repeat warnings when there are no off or on ramps surely the 'bong' and the speed limit sign is sufficient should you creep into transgression? |
253 Lifetime Member
Joined: Mar 05, 2007 Posts: 1058 Location: The green bit between the M40, M4 and M25.
Posted: Wed Dec 19, 2012 3:55 pm Post subject: |
Don't drive that part of the M25 so can't comment about the warnings etc.
I have a Galaxy S3 and have the shortened warning, I think it is better than the long one to be honest.
If it is the overspeed warning you are getting, you can turn it off in the CA settings, then advanced settings, there is an option in there. _________________ Triumph Tbird 1700. And now a Bonnie T100. |
Posted: Fri Dec 21, 2012 9:13 am Post subject: Cameralert has stopped working. |
I have reach a compromise with the warnings but why does this continually stop working and have to be reset? |
M8TJT The Other Tired Old Man
Posted: Fri Dec 21, 2012 10:30 am Post subject: Re: Cameralert has stopped working |
wetdogleader wrote: | Also having the voice alerts set to long when you come round the M25 past the M26 junction where you are in a 50mph speed limit through the current road works this thing goes of alarming! So much so that after about 10 warnings going through this stretch it drove me mad and I had to turn it off. | There are shedloads of specs in this location. If it didn't warn for all the cams then; a. The av speed would not be reset at the right time, and b, There would be lots of reports for missing cams. |
