Simon1 Frequent Visitor
Posted: Wed Sep 01, 2004 9:38 pm Post subject: |
Boy this is an eyeopener, delboy.
I am running an AMD 500Mhz processor but I haven't had any problems in the past running my MiniDV camera, Scanner and CD Burner all on USB. Does this mean I should be okay or is it possible that the TTG will still require me to download the driver you mention? |
delboy0754 Frequent Visitor
Joined: Jul 10, 2004 Posts: 296 Location: In the Office
Posted: Thu Sep 02, 2004 7:05 am Post subject: |
Simon1 wrote: | Boy this is an eyeopener, delboy.
Hi Simon,
As your already using USB equipment, i see no reason why the TT Go shouldn't work also. After all, it is a Mass Storage device your downloading to, the SD Card. It wouldn'y harm anything to download the driver i mentioned, as there are NO drivers on the CD that comes with TT Go, it uses GENERIC USB drivers, so it will recognise your SD card as just another storage device, like your hard drive. |
Posted: Thu Sep 02, 2004 9:53 am Post subject: |
Cheers for that. Normally I would be cautious asking advice from someone who flashes Bart's Butt at me, but you seem to know your stuff!! |
Posted: Thu Sep 02, 2004 1:12 pm Post subject: |
Simon1 wrote: | Cheers for that. Normally I would be cautious asking advice from someone who flashes Bart's Butt at me, but you seem to know your stuff!! |
Good luck with it Simon. you should find it works OK.
I'de better not say to much, might get accused of going off topic. |
jaybee Occasional Visitor
![](modules/Forums/images/avatars/half_planet.jpg)
Posted: Mon Sep 06, 2004 12:55 am Post subject: |
I have just completed 1400miles using TTG. The earlier part of my journey I was driving up the A9 towards Perth in the evening and thought I had better have a top up of fuel. I know there are fuel stations on Perth retail parks [westside of Perth] so I would head for one of those. However upon reaching the roundabout south of Perth the TTG gave directions to go straight across the roundabout then turn right and lo and behold there was an Esso service station which had recently been opened. Better still the fuel was the cheapest I had seen for some miles. The TTG POI is set to show fuel stations - but it did not lead me into another service station, as above, for the remainder of the week.
I was hoping to travel back past the Perth service station on my return, just to see if it was still there or if TTG would direct me again - but could not do so. Has this happened to anyone else? I feel as though the service station was put there for my benefit as the staff were so helpful showing me the best buys etc. not like the usual service station at all. |
sifi Regular Visitor
Joined: Nov 19, 2003 Posts: 125 Location: Lincolnshire
Posted: Mon Sep 06, 2004 11:15 am Post subject: |
I'm not exactly certain what you mean but you could browse the map for around Perth and enable the poi of petrol stations so hte petrol iconise shown on the map. This way you can view which are in its data base |
Posted: Mon Sep 06, 2004 11:19 am Post subject: |
for "iconise" read icon is shown. I must read what I write before submitting! |
Lampman Occasional Visitor
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Mon Sep 06, 2004 12:22 pm Post subject: |
Sounds like one for Mulder and Sculley! ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
AlanH Occasional Visitor
Posted: Mon Sep 06, 2004 9:40 pm Post subject: |
Quick question from a newbie, expecting delivery of TTG tomorrow from Expansys (incidentally, they increased their price yesterday)
Is it possible to enter a journey when TTG is out of sight of the GPS satellites, for example at home rather than in the car?
Thanks. |
TartanGiant Occasional Visitor
Posted: Mon Sep 06, 2004 9:55 pm Post subject: Out of Sat sights |
Hello AlanH,
Welcome........... and the answer is YES!
I programme mine before I step outside and into the gaze of the satellites, then plug it into the holder, and by that time it has locked on to enough to do the job. Sometimes it takes a few minutes but it gets them eventualy.
I was saying earlier to the chaps, my reception rate/sat hold was dreadful, but after buying a RE-rad it holds the signals much better .
Hope this helps.
TG |
Posted: Mon Sep 06, 2004 10:03 pm Post subject: |
Hi TartanGiant
Thanks for the quick reply! I was hoping the answer was yes.
Great forum, BTW. |
Posted: Mon Sep 06, 2004 10:08 pm Post subject: |
You can also use the "plan from A to B" in your home to see which route it chooses then modify if need with a via point (or an alternative route). Doing this at your leisure may speeds things up when you use it to navigate outside. |
MrRubberGloves Regular Visitor
![](modules/Forums/images/avatars/7402845004294818d29214.jpg)
Joined: May 09, 2004 Posts: 163 Location: Blackpool, England.
Posted: Tue Sep 07, 2004 1:25 pm Post subject: |
sifi wrote: | You can also use the "plan from A to B" in your home to see which route it chooses then modify if need with a via point (or an alternative route). Doing this at your leisure may speeds things up when you use it to navigate outside. |
When I plan a route from A to B (with my current location being C) and after it has given me the route to taks, if I were to modify the route ie by telling it to go via the alternative route option it always calculates it from C to B, anyone else suffer from this? |
Posted: Tue Sep 07, 2004 1:52 pm Post subject: |
Done a quick check and mine does the same. Not noticed it before because I've always used home as the starting point. The latter does do A to B to C as expected. I'll have a look at the book to see if it says anything relevant. |
Posted: Tue Sep 07, 2004 2:06 pm Post subject: |
Strictly speaking my A to B to C should be A to C to B where A is the start and C is the via and B hte destination. |
