Pocket GPS World :: View topic - Putting into hibernate
davidor
PostPosted: Wed Oct 24, 2012 8:50 am    Post subject: Putting into hibernate Reply with quote
OK, so I understand the settings for going into hibernate mode after a set period of inactivity, but how do I out it into hibernate manually, i.e. now? The manual says "Switch the unit into Hibernate mode (Settings -
Advanced Power Control - Hibernate Timeout)," but there is no option to "hibernate now", only either 'never' or a number of hours.
Is it possible to go straight to hibernate mode?
Would be useful as I could set up the route etc, then go into hibernate while I drive to the start then wake it up so it would be much quicker at being ready.
4ndynorfolk
PostPosted: Fri Oct 26, 2012 1:11 pm    Post subject: Reply with quote
The hibernate setting dictates what happens when you turn the unit off. It either goes straight to off or it goes into deep sleep for n hours before turning off completely.
As you have probably found hibernate allows a faster fix on turn on.
davidor
PostPosted: Sat Oct 27, 2012 10:05 am    Post subject: Reply with quote
Ah - I think I misunderstood how the hibernate timeout works. I thought that if it was set to say 2 hours, then it would go into hibernate mode after that time. As I now understand it, if hibernate is set for say 2 hours, when I turn the A10 "off" it will actually go straight into hibernate mode for 2 hours before powering off completely.
Thanks Andy for enlightening me.
