Pocket GPS World :: View topic - Vauxhall/Opel Touch & Connect
bobreeves
PostPosted: Fri Oct 05, 2012 6:23 am    Post subject: Vauxhall/Opel Touch & Connect Reply with quote
Hi, I am in the process of buying a new Vauxhall Antara SE Nav. The handbook states that it is possible to input user warning POI's. My question is do Pocket GPS World support it or will it be supporting the speed camera alerts for this system. The system is called (Opel) Touch & Connect.
On reading the manual the following format is required;
9.0695200,49.2109400,"[74906] 24h Autohof Wilhelm-Hauff Strasse 43 [Bad Rappenau]"
10.0017300,49.9118000,"[97262] 24h Autohof Am Wiesenweg 11 [Hausen]"
11.4743100,49.3133300,"[92348] 24h Autohof Ludwig-Erhard Ring 2 [Berg]"
11.3043500,51.4503900,"[06526] 24h Autohof Am Mittelfeld 5 [Sangerhausen]"
8.6631400,48.3435400,"[72189] 24h Autohof Eythstrasse 16 [Vöhringen]"
12.1354100,49.5327900,"[92533] 24h Autohof Keplerstrasse 1 [Wernberg-Köblitz]"
9.0070900,50.1818100,"[63526] 24h Autohof Röntgenstrasse 1 [Erlensee]"
12.7067900,51.2611900,"(04720)) Autohof Muldental; Am Heiterer Blick 2; LPG (Groß Weitzschen)"
8.2680400,49.9996000,"Tankstellen"
7.1182200,51.6846800,"Rainer Müller"
Sorry that the language is German.
If you recognise this format as one supplied by PocketGPSworld please let me know.
PostPosted: Fri Oct 05, 2012 7:02 am    Post subject: Reply with quote
It looks like a standard CSV or ASC File.
You might need to experiment with whether it needs a 'header' or not. Use the Free POIs on this site (they have both CSV and ASC variants), to see which is the better.
Does the Manual give any indication on how many such Files it can handle? Or does it load all POI locations into one large File?
TT Via 135 App 12.075: Europe Map v1145
Marlyn
PostPosted: Fri Oct 05, 2012 8:20 am    Post subject: Reply with quote
Hi Bobreeves if you dowload the manual from http://www.vauxhall.co.uk/manuals.html select Antara. On page 45 it gives you all the info about poi's Very Happy Mark
bobreeves
PostPosted: Fri Oct 05, 2012 9:14 am    Post subject: Reply with quote
Hi Oldboy,
This is what the manual states;
1. In the root directory of a USB
drive: create a folder
named "myPOIs",
e.g. "F:\myPOIs", where "F:\" is
the root directory of the USB drive.
2. In the "myPOIs" folder, store the
text file with destination POIs,
e.g. "F:\myPOIs
\TomsDestinationPOIs.asc".
3. In the folder "myPOIs" create a
subfolder
named "myPOIWarnings".
4. In that subfolder store the text file
with POI warnings,
e.g. "F:\myPOIs\myPOIWarnings
\TomsPOIWarnings.asc"
As to the amount of POI;s I have read somewhere that it is in the region of 15,000
PostPosted: Fri Oct 05, 2012 10:53 am    Post subject: Reply with quote
It would appear that you can have only 1 POI File, as a Destination File, and another File that handles Warnings, such as Speed Cameras.
For Speed Cameras you would need to use Other - ASC and, as there's no mention of it, delete the first line - which is the header - and place it in the POI Warnings Folder.
How it would best announce a Warning would need further experimenting.
For use with 'ordinary' POIs, the POI file would need to go in the MyPOIs Folder
bobreeves
PostPosted: Fri Oct 05, 2012 11:24 am    Post subject: Reply with quote
Thanks to everybody for all your help, I think I will be able to make it work now!
