Andy_P Pocket GPS Moderator
Posted: Mon Sep 24, 2012 1:19 am Post subject: |
hijacker wrote: | The problem lies with the ON/OFF button which sticks when pressed down. (the plastic outer button not the microswitch on the circuit board). |
mikealder wrote: | Have a look on e-bay for a non-working x40 or x50 device and buy that then swap out the deffective parts of the on/ off switch - Mike |
That would mean swapping the entire rear half of the case, as the "springs" for the switch button are just two plastic strips ultrasonically welded to the case. _________________ "Settling in nicely" ;-) |
hijacker Regular Visitor
Posted: Mon Sep 24, 2012 3:14 pm Post subject: |
Thanks for all replies so far.
I've decided I'm just going to replace my 940. I want a device that has LIVE services and can be attached to a powered bracket (similar to my existing 940). This appears to leave me with the x1000 series but I hear mixed reviews although the hardware review on this site by Mike Barrett gives it 8.5/10 which I would say is pretty good.
Think I will try the 1005 and see for myself and if it's too bad then I'll just send it back. _________________ TT GO 1005 |
JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Sat Feb 23, 2013 3:45 pm Post subject: |
Andy_P wrote: | hijacker wrote: | The problem lies with the ON/OFF button which sticks when pressed down. (the plastic outer button not the microswitch on the circuit board). |
That would mean swapping the entire rear half of the case, as the "springs" for the switch button are just two plastic strips ultrasonically welded to the case. | I've been having this problem recently! I've found that leaving the top right case screw loose, seems to allow the external button to "pop up", rather than get stuck down - hopefully this will see me through until eBay throws up a donor.
Can someone confirm that the external case for the 540, 550, 740, 750, 940 & 950 are all the same? And remind me what the functional differences between the 940 & 950 were? _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
rwbaldwin Occasional Visitor
