hijacker Regular Visitor
Posted: Fri Feb 03, 2012 9:09 pm Post subject: Sticking On/Off button (x40) |
My 940 has developed a sticking on/off button.
Does anyone know if this is an easy/cheap fix? I'm willing to dismantle it myself if necessary.
Thanks. _________________ TT GO 1005 |
Andy_P Pocket GPS Moderator
Posted: Fri Feb 03, 2012 9:19 pm Post subject: |
If you fancy taking the unit apart, do a forum search for battery changing as the disassembly steps will be the same.
It's possible the switch itself is OK, but its the plastic actuator that's sticking.
If not, the switch itself is a 20p part (if you can source a replacement), but it is a surface-mount component on a multilayer printed circuit board.
Unless you are used to working on such things, then I'm afraid you won't have the equipment needed to do the micro-soldering required to swap the switch. _________________ "Settling in nicely" ;-) |
JockTamsonsBairn Lifetime Member
Posted: Fri Feb 03, 2012 11:21 pm Post subject: |
Andy_P wrote: | do a forum search for battery changing | I can't find anything here, but Googling "Tomtom 940 strange issue - looking for any ideas - Page 2" throws up a thread that you and Mike contributed to on another forum. Can we cross-post links to the other forums? _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Fri Feb 03, 2012 11:52 pm Post subject: |
thanks for replies.
i'll open it up and take a look. _________________ TT GO 1005 |
Posted: Sat Feb 04, 2012 12:51 am Post subject: |
JockTamsonsBairn wrote: | Andy_P wrote: | do a forum search for battery changing | I can't find anything here, |
There's this...
x40/ x50 Battery Change
JockTamsonsBairn wrote: | Can we cross-post links to the other forums? |
Yes no problem.... _________________ "Settling in nicely" ;-) |
Posted: Sun Feb 05, 2012 3:52 pm Post subject: |
Well searched!  _________________ Jock
Posted: Sun Sep 16, 2012 10:48 am Post subject: |
Since I first started this thread the button has finally failed.
Whenever pressed it remains down, right of centre more than anything, causing the device to be in a constant state of reboot.
I've removed the button leaving the 940 only operational via the small button on the circuit board itself which is not a long term solution for me.
Does anyone know of any repair options here or should I start my search for an alternative sat nav now? _________________ TT GO 1005 |
justbrowsing Frequent Visitor
Posted: Sun Sep 16, 2012 11:13 am Post subject: |
You could google "tomtom repairs" & get a few quotes as it's going to be cheaper than a new device for sure |
Posted: Sun Sep 16, 2012 11:17 am Post subject: |
I did get one quote of £50! I'm not really looking to spend much on my 940 now given it's age. Sods law I pay for a repair and something else fails the following week. _________________ TT GO 1005 |
Greenglide Lifetime Member
Joined: Apr 04, 2006 Posts: 295 Location: South East Northumberland, UK
Posted: Sun Sep 16, 2012 12:30 pm Post subject: |
hijacker wrote: | I did get one quote of £50! I'm not really looking to spend much on my 940 now given it's age. Sods law I pay for a repair and something else fails the following week. |
Can you not use eBay (or similar auction site) to obtain a cheap, possibly non functional, TT Go x40 (any 40 series would do) and pinch the plastic switch out of that?
Assuming it is just the button failed, not the switch. _________________ TomTom Go 540 - V9.058, Map GB & Ireland 860.3101
TomTom Go 520T, V8.351, TTS V7, Map GB & Ireland 855.2884
Nokia 5800 with Google Maps & OVI Maps
Google Nexus One with Google Maps & NDrive |
aerotec Regular Visitor
Joined: 27/07/2003 22:05:35 Posts: 130 Location: United Kingdom
Posted: Sun Sep 16, 2012 3:44 pm Post subject: |
I sometimes get my button stocking but find that if I hold backward pressure so the button is pushed towards the rear of the device I am able to power it on/or off without it sticking. If the button is jamming on the housing has anyone tried a drop of light oil to lubricate it? |
jonial Regular Visitor
Joined: May 10, 2004 Posts: 160 Location: Garstang, Lancashire
Posted: Sun Sep 16, 2012 4:07 pm Post subject: |
A bit of a long shot but try a few drops of isopropyl alcohol on the button.
It cleared a sticking shutter release button on my camera _________________ Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras |
Posted: Sun Sep 23, 2012 10:53 am Post subject: |
Finally opened up the 940......and found a small piece of the black plastic ON/OFF button still attached inside the case. The two small pieces either side of this button are located in the case and give the button its springiness. _________________ TT GO 1005 |
