Pocket GPS World :: View topic - poi
poi
BONDEY
PostPosted: Fri Sep 14, 2012 10:18 pm    Post subject: poi Reply with quote
Downloaded a poi of pocket gps the kfc poi. its a ov2 file will it work in nissan connect and if so how do i install it thanks
PostPosted: Sat Sep 15, 2012 7:00 am    Post subject: Reply with quote
Follow the instructions given Here. This should give you an idea of how to go about it, but just replace any reference to speed cameras, with the POI file(s), and you will need the CSV version.
Reading through it, it seems as if you can only have 1 POI file in the unit. With this in mind, if you wanted another POI (say McDonalds), you would have to combine the 2 files. This can be done on the Download Page, and the whole process repeated again.
If there are any mistakes in the above, I'm sure someone who has already gone through this process will come along and correct me.
TT Via 135 App 12.075: Europe Map v1145
SteveMPS
PostPosted: Sat Jan 26, 2013 1:31 am    Post subject: Reply with quote
Oldboy wrote:
Follow the instructions given Here. This should give you an idea of how to go about it . . .
Can I just double check that
10. New POI data will overwrite POI data already in the internal memory
Means it will overwrite only previously downloaded PGPSW cameras. If I take the words literally it could mean it will erase all POI information in the Nissan unit
Don't really want to do that or even risk it
PostPosted: Sat Jan 26, 2013 7:41 am    Post subject: Reply with quote
I don't have personal experience of the system but, reading through the instructions, it would appear that you can have only 1 MyPOI File.
If I am right, then Yes, it will delete ALL current POI information. You would need to combine all POI information into 1 CSV File on the USB stick.
I don't know if there is a method to overcome this limitation.
PostPosted: Sat Jan 26, 2013 10:48 am    Post subject: Reply with quote
Unless the OP is referring to the built in POI. But I still wouldn't risk it without more knowledge.
SteveMPS
PostPosted: Sat Jan 26, 2013 11:38 am    Post subject: Reply with quote
Thanks both
If it were my Nissan I'd risk it but it's hers so probably won't as there's always the iPhone app I can run in parallel.
SteveMPS
PostPosted: Sat May 02, 2015 8:28 pm    Post subject: Reply with quote
Well 2 years later . . . . .
Finally risked giving it a try. Good news
- the PGPSW data overwrites all the previous camera warnings
- it does not overwrite any other Points of Interest
Smile
PostPosted: Mon May 04, 2015 6:49 pm    Post subject: Reply with quote
Good result after all this time then. ;=)
SteveMPS
PostPosted: Fri May 29, 2015 3:21 pm    Post subject: Reply with quote
Also as it's a CSV file you can easily edit it to trim down the on screen message it gives.
I took out the camera ID, the "camera ahead" and WARNING! words from 13,000 entries to declutter the screen
Bad news is for some daft reason Nissan seem to have left some of the motorway roadworks warnings on the SD card so they are not removed. So you get warned about work that ended 3 years ago.
Ah well
23.034 (26 Mar 25)
