Pocket GPS World :: View topic - garmin nuvi 300 - Screen freezes on external power
blokester
PostPosted: Sat Sep 08, 2012 3:23 pm    Post subject: garmin nuvi 300 - Screen freezes on external power Reply with quote
I have a Nuvi 300 which hasn't been used for a while. When I connect it to the 12 volt car adapter the screen freezes, the power switch stops working and a monitor screen and what looks like an upright freezer icon appear at the bottom of the display.
When the power is disconnected it appears to work fine.
Any ideas whats causing this?
PhilHornby
PostPosted: Sun Sep 09, 2012 5:42 pm    Post subject: Re: garmin nuvi 300 - Screen freezes on external power Reply with quote
It's gone into 'Mass Storage Mode' - it thinks it's connected to a PC (not a freezer Laughing )
The most likely cause, is that you've connected a non-Garmin charger, directly to the unit. If you plug it into the cradle it will work. A Garmin charger will work in either connection - although the cradle connection makes most sense.
blokester
PostPosted: Sun Sep 09, 2012 8:27 pm    Post subject: Reply with quote
It is a garmin charger and worked a treat when connected to the cradle but used to work in my other car plugged in direct. thanks for the reply.
22.094 (25 Sep 24)
