CAA_0821145133 Occasional Visitor
Posted: Wed Sep 05, 2012 8:37 pm Post subject: Sept 5 database |
how come I have only two .gpx files? |
Posted: Wed Sep 05, 2012 10:15 pm Post subject: Help |
Edit: Sorted
Just hope someone can figure out a way for audible warning |
Artnithi Occasional Visitor
Posted: Sun Sep 09, 2012 4:33 pm Post subject: Mercedes GPX converter |
I am a newbie here, I want to convert my Garmin waypoints to Comand Online. After reading the thread, I found that Merc twisted the GPX.
I have my waypoints in GPX file from Garmin Basecamp.
I haven' found the Mercedes Comand in download section here. Can you point me the right place.
Thanks.
Art |
jojo19 Occasional Visitor
Posted: Sun Sep 09, 2012 9:59 pm Post subject: Re: Mercedes GPX converter |
Artnithi wrote: | I am a newbie here, I want to convert my Garmin waypoints to Comand Online. After reading the thread, I found that Merc twisted the GPX.
Thanks.
Art |
Same, please... |
CA_0223151745 Occasional Visitor
Posted: Thu Sep 20, 2012 2:13 pm Post subject: Multiple audible warnings |
I've just joined and just downloaded the Merc gpx files for the first time. I've edited to make Active="True" Level="Warning" and going to try it out on my way home tonight.
With regard to multiple warnings, presumably if you duplicated each entry, but changed
ShowOnMap="true"
to = "false"
the camera would not appear twice on the map but might produce two audible warnings if the seconds settings are different. I might give that a go tomorrow. First-things-first, lets hope the audible warnings work on my 2011 E-Class comand online (that won't go online with an iPhone and my Merc dealer says they have no plans for my Comand to be updated, even after the salesman told me it would work with an iPhone, but that's a different thread). |
Posted: Fri Sep 21, 2012 11:19 am Post subject: Audible warning doesn't work |
Tried the settings suggested (active = true & level = warning) but no audible warning on C207 Comand online (2011). |
Posted: Sun Nov 18, 2012 5:47 pm Post subject: |
i intend to put archies campings on NTG 4.5, but the system don't load the file i have in the PersonalPOI.
i get the file from a garmim GPX file and i didn't understand if i need to make some changes to the file or not.
some help...
pls |
wychwoods Occasional Visitor
Joined: Sep 21, 2004 Posts: 16 Location: Herts/Essex border
Posted: Fri Nov 23, 2012 2:45 pm Post subject: Brilliant! |
Thanks to everyone that got the PGPS database into Mercedes Comand format.
All I need now is to find out if other important db's like the Good Beer Guide POIs are available in Mercedes format - any ideas?
Cheers,
Frank _________________ TT GO, OS 7.163,
2Gb SD card, Western Europe map v710.1561 |
CDPDesign Occasional Visitor
Posted: Tue May 07, 2013 4:11 pm Post subject: 2007 CLS |
We have a 2007 CLS320 that has the command unit but no SD card slot. Can the mercedes files be burnt to a CD and uploaded to the unit that way, or does that edition of the Command unit not support the POI's? |
vitobrabus Occasional Visitor
Posted: Wed May 15, 2013 4:22 pm Post subject: |
Am I missing something. Got a 2013 vito with ntg4.5 i think??
Created PersonalPOI folder and unpacked the download to it.... Get in the van, insert sd card, turn on, press navi, select navi in the menu bar.... then I cannot find anything about POI's. Been through all the menus and cant find how to import the data.
Anyone point me in the right direction? |
Posted: Wed May 15, 2013 11:54 pm Post subject: |
Balls... Turns out I have ntg2.5 so no cameras for me. |
m1bjr Occasional Visitor
Joined: Dec 26, 2006 Posts: 1 Location: United Kingdom
Posted: Mon May 27, 2013 7:15 pm Post subject: 2013 COMAND has Audible alerts for personal POIs |
We were banding a few ideas on an MB forum recently.
I have the new E Class with COMAND online (April 2013).
There is a 'bong' sound available as an audible alert now.
It seems you must enable the parameter "warning" in the POI script as earlier in this thread (instead of "information").
This seems to enable a simple chime not unlike a passenger aircraft "fasten seatbelts" gong.
I need to do a little more experimenting yet, but its definitely working for me.
Any POI group enabled with a tick in COMAND produces a gong if the script is set up this way.
The downside is that they seem to be radius (proximity) related and there is no facility for alert 'only on route' like a TomTom device sing camera POIs.
HTH?
Steve _________________ Kind Regards,
Steve |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15409 Location: Bradford, West Yorkshire
Posted: Mon May 27, 2013 7:36 pm Post subject: Re: 2013 COMAND has Audible alerts for personal POIs |
m1bjr wrote: | It seems you must enable the parameter "warning" in the POI script as earlier in this thread (instead of "information").
This seems to enable a simple chime not unlike a passenger aircraft "fasten seatbelts" gong. |
Is this something that you want changing in the downloaded file? Obviously we'd need to check it didn't have adverse effects on different systems etc...
MaFt |
spring167 Occasional Visitor
Posted: Fri May 31, 2013 2:21 pm Post subject: |
I am soon to take delivery of a 2013 E class which I believe has Command Online.
As a newbie to this forum where exactly would I find the POIs ncessary to implement the things mentioned in this thread?
Thanks |
im333 Occasional Visitor
Posted: Wed Jul 03, 2013 8:10 pm Post subject: |
Hi all,
About to take delivery of my new 2013 e class with COMMAND and wait with baited breath as some kind soul points me in the direction of DIY instructions to get this working!
im333 |
