Pocket GPS World :: View topic - Trouble Downloading 8.95 Map For 1005
HummerUK
PostPosted: Mon Aug 27, 2012 8:53 am    Post subject: Trouble Downloading 8.95 Map For 1005 Reply with quote
The download makes no progress and them comes up with this dialogue
Failed to download content for your TomTom GO LIVE 1005 with ID SA2470K00xxx
Please consult your network settings.
The URL is as follows:
http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg.
Any thoughts?
Tried router and pc restart.
HummerUK
jonbaker12345
PostPosted: Mon Aug 27, 2012 9:09 am    Post subject: Reply with quote
Map 895 downloaded & installed onto my 550 Live via Home. Haven't had chance to check out the new map yet, but seems to be functioning OK, which is a blessing Smile
I noticed it also downloaded "Navigating To A Postcode".
No UK safety camera updates (again!) ....
HummerUK
PostPosted: Mon Aug 27, 2012 12:58 pm    Post subject: Reply with quote
Still no luck Sad
I have tried everything I can think of and can only assume the morons at TomTom have made yet another blunder.
HummerUK
dhn
PostPosted: Mon Aug 27, 2012 1:30 pm    Post subject: Reply with quote
Have you tried changing the port settings in the desktop's MyTT settings? Try 4001.
Also, might you have a firewall or anti-virus blocking transmission?
HummerUK
PostPosted: Mon Aug 27, 2012 2:20 pm    Post subject: Reply with quote
Yes, tried different ports which pass the test and have also tried with my firewall turned off.
Anyone else tried to update their map today?
HummerUK
moatgoat
PostPosted: Mon Aug 27, 2012 2:55 pm    Post subject: Map 895 Reply with quote
Downloaded on my 920 okay
nibor
PostPosted: Mon Aug 27, 2012 3:13 pm    Post subject: Reply with quote
All OK Here Very Happy
Anita
PostPosted: Mon Aug 27, 2012 4:30 pm    Post subject: Reply with quote
It would be helpful if replies could state the device so we can see whether everyone having problems (if there are any others) is using My TomTom, like the OP.
All seems fine with UK&RoI on my 720 using TT Home
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
HummerUK
PostPosted: Mon Aug 27, 2012 4:38 pm    Post subject: Reply with quote
Still no luck for me but looking at the path in the error message
I notice it has nav3 in it twice.
That seems a funny thing to do...
If you put http://download.tomtom.com/895/nav3/Europe.ttpkg you get an access forbidden message rather than not found error which seems more reasonable.
HummerUK
dhn
PostPosted: Mon Aug 27, 2012 4:55 pm    Post subject: Reply with quote
Some information from a poster on TT's discussion forums:
Well I solved it myself in the end -- no word back from TomTom.
In case anyone else has the same problem, you can use my workaround. Really TomTom should fix the cause, but hey.
To fix invalid certificate problem:
1) Follow these instructions to download the 'debug' menu for TomTom Home: http://create.tomtom.com/developers/debug-menu.htm​l
2) Once you've got the Debug menu available, click it then select 'Certificate manager'.
3) Click 'Servers'.
4) Click 'Add Exception ..."
5) In 'Location' enter 'https://download.tomtom.com'
6) Click 'Confirm Security Exception'
Hopefully that should do it.
HummerUK
PostPosted: Mon Aug 27, 2012 5:46 pm    Post subject: Reply with quote
I think that may be for TomTom Home rather than MyTomTom?
http://create.tomtom.com/developers/debug-menu.html
HummerUK
3) Click 'Servers'.
dhn
PostPosted: Mon Aug 27, 2012 7:59 pm    Post subject: Reply with quote
Yeah, sorry.......
Just wond if you clear the cache on your desktop's icon and see if the download is offered again.
Honestly, I'm seeing posts in various forums of successful dl's of 895 maps for Nav3 devices in Europe.
So, it is not an issue as such with TomTom, I would think....
If you go to Computer Management in your Control Panel, do you see an exclamation mark beside network adapters (which your device shoul show as)?
You might want to try disabling that Network adapter and re-enable.
dirtyweeraincloud
PostPosted: Mon Aug 27, 2012 9:51 pm    Post subject: Reply with quote
Successfully downloaded and installed map to my 1005 Very Happy
HummerUK
PostPosted: Tue Aug 28, 2012 7:24 am    Post subject: Reply with quote
Just turned my laptop on this morning and this time it is working okay and is at 6%.
I have changed nothing so I guess a problem at their end or with my ISP?
The error log in the application had this in it BTW
Code:
2012-08-27 10:59:28.104|50331698|Error|DownloadFileCache::SendRequests|
2012-08-27 12:45:42.600|50331698|Error|DownloadFileCache::SendRequests|Cache error. Error code: 301. Error message: Error downloading http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg - server replied: Gateway Time-out. CachedItem:[URL:http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg;Index:11;ServerStatusCode:504;StatusCode:504;Percentage:0;ResumeCount:5;ContentLength:176;CacheLength:0;ResumeLength:0;MUIDs:[MUID:SA2470K000xx];Complete:0;InCache:0;ServerRespectBytes:0;IsHead:0;RequestDelayed:0]
2012-08-27 12:54:04.608|50331698|Error|DownloadFileCache::SendRequests|
2012-08-27 12:58:30.355|50331698|Error|DownloadFileCache::SendRequests|Cache error. Error code: 301. Error message: Error downloading http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg - server replied: Gateway Time-out. CachedItem:[URL:http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg;Index:11;ServerStatusCode:504;StatusCode:504;Percentage:0;ResumeCount:5;ContentLength:176;CacheLength:0;ResumeLength:0;MUIDs:[MUID:SA2470K000xx];Complete:0;InCache:0;ServerRespectBytes:0;IsHead:0;RequestDelayed:0]
2012-08-27 13:02:14.965|50331698|Error|DownloadFileCache::SendRequests|Cache error. Error code: 301. Error message: Error downloading http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg - server replied: Gateway Time-out. CachedItem:[URL:http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg;Index:11;ServerStatusCode:504;StatusCode:504;Percentage:0;ResumeCount:5;ContentLength:176;CacheLength:0;ResumeLength:0;MUIDs:[MUID:SA2470K000xx];Complete:0;InCache:0;ServerRespectBytes:0;IsHead:0;RequestDelayed:0]
2012-08-27 13:05:42.085|50331698|Error|DownloadFileCache::SendRequests|Cache error. Error code: 301. Error message: Error downloading http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg - server replied: Gateway Time-out. CachedItem:[URL:http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg;Index:1;ServerStatusCode:504;StatusCode:504;Percentage:0;ResumeCount:5;ContentLength:176;CacheLength:0;ResumeLength:0;MUIDs:[MUID:SA2470K000xx];Complete:0;InCache:0;ServerRespectBytes:0;IsHead:0;RequestDelayed:0]
2012-08-27 13:11:35.000|50331698|Error|DownloadFileCache::SendRequests|Cache error. Error code: 301. Error message: Error downloading http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg - server replied: Gateway Time-out. CachedItem:[URL:http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg;Index:1;ServerStatusCode:504;StatusCode:504;Percentage:0;ResumeCount:5;ContentLength:176;CacheLength:0;ResumeLength:0;MUIDs:[MUID:SA2470K000xx];Complete:0;InCache:0;ServerRespectBytes:0;IsHead:0;RequestDelayed:0]
2012-08-27 13:13:53.868|50331698|Error|DownloadFileCache::SendRequests|Cache error. Error code: 301. Error message: Error downloading http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg - server replied: Gateway Time-out. CachedItem:[URL:http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg;Index:1;ServerStatusCode:504;StatusCode:504;Percentage:0;ResumeCount:5;ContentLength:176;CacheLength:0;ResumeLength:0;MUIDs:[MUID:SA2470K000xx];Complete:0;InCache:0;ServerRespectBytes:0;IsHead:0;RequestDelayed:0]
2012-08-27 16:30:16.042|50331698|Error|DownloadFileCache::SendRequests|Cache error. Error code: 301. Error message: Error downloading http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg - server replied: Gateway Time-out. CachedItem:[URL:http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg;Index:1;ServerStatusCode:504;StatusCode:504;Percentage:0;ResumeCount:5;ContentLength:176;CacheLength:0;ResumeLength:0;MUIDs:[MUID:SA2470K000xx];Complete:0;InCache:0;ServerRespectBytes:0;IsHead:0;RequestDelayed:0]
2012-08-27 17:45:04.345|50331698|Error|DownloadFileCache::SendRequests|Cache error. Error code: 301. Error message: Error downloading http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg - server replied: Gateway Time-out. CachedItem:[URL:http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg;Index:1;ServerStatusCode:504;StatusCode:504;Percentage:0;ResumeCount:4;ContentLength:176;CacheLength:0;ResumeLength:0;MUIDs:[MUID:SA2470K000xx];Complete:0;InCache:0;ServerRespectBytes:0;IsHead:0;RequestDelayed:0]
2012-08-27 22:26:00.265|50331698|Error|DownloadFileCache::SendRequests|Cache error. Error code: 301. Error message: Error downloading http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg - server replied: Gateway Time-out. CachedItem:[URL:http://download.tomtom.com/nav3/895/nav3/Europe.ttpkg;Index:1;ServerStatusCode:504;StatusCode:504;Percentage:0;ResumeCount:4;ContentLength:176;CacheLength:0;ResumeLength:0;MUIDs:[MUID:SA2470K000xx];Complete:0;InCache:0;ServerRespectBytes:0;IsHead:0;RequestDelayed:0]
HummerUK
HummerUK
PostPosted: Tue Aug 28, 2012 8:55 am    Post subject: Reply with quote
All installed okay with a 3,093,085KB file now in the cache folder.
HummerUK
