thefella Occasional Visitor
Posted: Tue Mar 15, 2011 7:15 pm Post subject: 1490TV startup problem |
When I plug my garmin into the 12v in my car and switch it on, it takes a while to load the maps. It thinks it connected to the computer and shows the computer symbol for a while then it disappears and starts up as normal. Does anyone know why this may be happening and if so how to cure it? |
SQUARE2024 Lifetime Member
Posted: Tue Mar 15, 2011 7:39 pm Post subject: |
Have you tried a full reset ?,touch [hold] the bottom right hand corner of screen when you turn on.not had the problem my self..............yet _________________ Square2024
TomTom 520
Christmas Draw 2010 Grand Final Winner Garmin Nuvi 1490TV |
Posted: Wed Mar 16, 2011 12:55 am Post subject: |
No I haven't tried that, I will try it tomorrow. Thanks. |
SandLake Regular Visitor
Posted: Sat Aug 04, 2012 1:28 pm Post subject: |
This problem has now started on my new 2495LMT. I updated the maps to 2013.10 and ever since it just thinks it is connected to a computer, the screen flashes the WhereTo/ViewMap screen but then shows the icon of SatNav wired to a PC.
I have tried a reset (switch on while touching the lower right side of the screen and erased user data) but the problem persists.
Any advice? |
Posted: Sat Aug 04, 2012 1:57 pm Post subject: |
Are you using the lead/charger that came with the unit? |
Posted: Sat Aug 04, 2012 2:01 pm Post subject: |
No, but I am using the cable that came with my Nuvi 265W. The 2495LMT cable has a traffic receiver in it which isn't applicable in Northern Ireland |
Posted: Sat Aug 04, 2012 2:05 pm Post subject: |
Try the original cable and see what happens.
I take you've been using the 265W cable for some time now? |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Sun Aug 05, 2012 9:21 am Post subject: |
That behaviour is invariably due to a faulty cable, so the advice to try the cable that came with it is a good one. I suspect the cable from the 265 is quite an old one and has probably failed in some way |
Posted: Wed Aug 08, 2012 12:12 pm Post subject: |
Sorry for being so long to respond
The original cable is working as it should, the unit comes on immediately, if you have significantly changed location since the unit was switched off it takes a few moments but there is no icon of a SatNav wired to a PC.
The original 265W cable is probably 6-8 years old now but it seems in good condition.
Thanks very much |
