Pocket GPS World :: View topic - Kenwood DNX7210BT - SD card not loading
CA_0330223251
PostPosted: Wed Jun 20, 2012 11:18 pm    Post subject: Kenwood DNX7210BT - SD card not loading Reply with quote
This is my first post. I'm looking for help in getting my Kenwood DNX7210BT to load the PocketGPSWorld database. I have a clean SD card with the Database loaded using Garmin's POI Loader. When the SD card is inserted into the Kenwood unit, a continuous message is displayed 'reading'.
The file structure setup by the POI Loader is Garmin/POI/pgpsw-speed-cams-J2Po--(10-061).gpi Am I doing something wrong ? Any advice is very much appreciated.
PaulB2005
PostPosted: Wed Jun 20, 2012 11:56 pm    Post subject: Reply with quote
Welcome.
Try renaming the file to poi.gpi
CA_0330223251
PostPosted: Thu Jun 21, 2012 12:05 pm    Post subject: Reply with quote
Many thanks for your prompt response. Unfortunately nothing changed using,
poi.gpi Also tried Garmin/POI/poi.gpi with no change. I'm sure this is the right track but it seems (from reading other forums) various Kenwood models are sensitive to different file names. Any over suggestions very welcome.
PaulB2005
PostPosted: Thu Jun 21, 2012 1:19 pm    Post subject: Reply with quote
The guide is here - http://www.pocketgpsworld.com/uksafetycameras-kenwood.php
You might need to mess about with the structure.
Start with
x:\garmin\poi.gpi
then
x:\Garmin\poi.gpi (Capital G!!)
x:\garmin\poi\poi.gpi
etc
Even try
x:\poi.gpi (NO Folders)
PaulB2005
PostPosted: Thu Jun 21, 2012 1:23 pm    Post subject: Reply with quote
Documentation on Kenwood website indicates the DNX7210BT will only use a USB stick for the POIs.
Also the structure has to be
x:\Garmin\Poi\Poi.gpi
The sentance case MAYBE relevant...
CA_0330223251
PostPosted: Thu Jun 28, 2012 8:47 pm    Post subject: Reply with quote
Gentlemen, problem solved, thanks to your useful guidance. I should have read the manual more carefully. USB as an input is the secret. It still required a little fiddling but putting the Kenwood into standby, prior to selecting navigation, seemed to be the final trick. I don't know if the file names are vital but I succeeded with Garmin/POI/Poi.gpi . Hope this helps future Kenwood users.
tiddler
PostPosted: Wed Nov 28, 2012 11:21 pm    Post subject: Kenwood 7210BT Reply with quote
PaulB2005 is correct. The USB connection has to be used. Just upgraded to this headunit myself, hope it's as good as the old 7260BT. Wink
23.021 (05 Feb 25)
