Pocket GPS World :: View topic - New v890 Postcodes
New v890 Postcodes
Goto page 1, 2, 3  Next
theripper
PostPosted: Mon Jun 04, 2012 9:30 pm    Post subject: New v890 Postcodes Reply with quote
The new postcode files are now available.
Here:
http://www.tomtom.com/updates/zipcodes/Map_890/zip.zip
Guivre46
PostPosted: Mon Jun 04, 2012 11:01 pm    Post subject: Problems for Some Devices Reply with quote
Thanks.
Edit: This is a bit unusual. Usually I get a 'zip.zip' file that needs renaming, but this download gives a 'zip' file straight away. I'll proceed with caution.
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
PaulB2005
PostPosted: Mon Jun 04, 2012 11:55 pm    Post subject: Reply with quote
Can/does this file work with older maps?
Why does the zip.zip file need renaming and to what??
dhn
PostPosted: Tue Jun 05, 2012 1:03 am    Post subject: Reply with quote
Yes, will work with older maps, Paul.
I wonder why the file would need renaming as well. WinRar understands what a 'zip' extension is......
theripper
PostPosted: Tue Jun 05, 2012 1:22 am    Post subject: Reply with quote
Guivre46 wrote:
Thanks.
I can't see the problem, it's a zip file with a zip directory inside, just extract to your unit and overwrite the files already there.
G4GVB
PostPosted: Tue Jun 05, 2012 8:15 am    Post subject: Reply with quote
I'm running 8.75 map and the new post codes won't work on mine, just get "File Access Error" when I try to run it. I've had to go back to 875 version.
EDIT:
I unzipped the new downloaded file and replaced the contents in the ZIP folder on the TT root.
GO 750 LIVE v9.430 - v8.753612 EU map
XL 350 MT v9.151 - v8.75366 US Map
PostPosted: Tue Jun 05, 2012 8:26 am    Post subject: Reply with quote
G4GVB wrote:
I'm running 8.75 map and the new post codes won't work on mine. I've had to go back to 875.
??? Shocked
Guivre46
PostPosted: Tue Jun 05, 2012 9:18 am    Post subject: Reply with quote
I'm running a mac + stuffit expander. I've tried the zip file on my One XL with 860 maps, and it cannot access the post code file. Have reverted to 860 postcodes.
Edit .....just to check things out, I redownloaded 860 postcodes from the PGPSW link. This gave me a decompressed zip.zip file on my desktop, which I renamed as zip and copied to the root directory. This is the process it has always been until the 890 version.
Edit2: reminded me I'd been going to put 885 on the XL. Went through the usual process and installed OK.
Kia In-dash Tomtom
justbrowsing
PostPosted: Tue Jun 05, 2012 10:47 am    Post subject: Reply with quote
I've installed these new 890 postcodes but when I try to navigate to post code it says "file access error"
I tried just replacing the files AND also tried replacing the zip folder too but both the same Grrrrr!
Biggles500
PostPosted: Tue Jun 05, 2012 11:00 am    Post subject: Reply with quote
I've also just installed the 890 postcodes, but they fail to work correctly.
Selecting the postcode option, when browsing the map, accepts the the first 3 digits, but doesn't bring up any street names etc..
Reverting to the previous version, normal operation resumes Confused
Garmin Drivesmart 50 LMT-D App 5.90
Full Europe Map 2026.20
alanlakes
PostPosted: Tue Jun 05, 2012 11:17 am    Post subject: Reply with quote
Same for me "File Access error" reverting to previous post code files.
Alan
Tomtom Go 6200, Tomtom GO Android app, Garmin GPSMap 62stc, Garmin Oregon 450, Memory map V5 & V6, Moto G6, CamerAlert, Copilot Premium, MM Tracker.
justbrowsing
PostPosted: Tue Jun 05, 2012 12:01 pm    Post subject: Reply with quote
Apparently the "Dutch" postcode "Nederland.postal" work fine, just not the UK ones
marksfish
PostPosted: Tue Jun 05, 2012 12:51 pm    Post subject: Reply with quote
How would you put this on a nav3 device please (when it's working ;) )?
dhn
PostPosted: Tue Jun 05, 2012 1:50 pm    Post subject: Reply with quote
TomTom has been advised of the problem with the UK files.
This is the response:
Somehow the incorrect side files ended up on the TT website. I have informed my colleagues in order to correct the mistake. No idea how long it will take to have the right files on the website, but I guess this should no more than one or two days??
Guivre46
PostPosted: Tue Jun 05, 2012 2:43 pm    Post subject: Reply with quote
dhn, good to see you have some clout with TT, I think you've earned it.
These are only for nav2 devices. For nav3 they have to be offered by MyTomtom or embedded in the map. I don't think they've sorted that yet?
Kia In-dash Tomtom
Page 1 of 3
23.084 (27 Aug 25)
