Pocket GPS World :: View topic - TT 1005 very slow
TT 1005 very slow
cabmanuk
PostPosted: Thu May 31, 2012 10:29 am    Post subject: TT 1005 very slow Reply with quote
Hi everyone
TT GO 1005 is all up to date and very slow to respond, seems to be worse after last map update. Should I do a factory reset? Any ideas.
cabmanuk Smile
PostPosted: Thu May 31, 2012 10:43 am    Post subject: Re: TT 1005 very slow Reply with quote
cabmanuk wrote:
... very slow to respond, ...
Slow to respond to what?
Screen taps? Map redraw when traveling?
If the latter, how many POIs are Enabled to show on the Map. More than 2 or 3 will dramatically slow down the refresh rate of the screen. Warn When Near does not have this drawback.
TT Via 135 App 12.075: Europe Map v1140
cabmanuk
PostPosted: Fri Jun 01, 2012 2:51 am    Post subject: Re: TT 1005 very slow Reply with quote
Hi Oldboy thanks for your reply
Screen taps seem slower. Confused
Floriank
PostPosted: Fri Jun 01, 2012 10:18 am    Post subject: Reply with quote
I agree, mine is just a pain to use nowadays.
It's the screen taps that take just too long to process. If I want to choose a favourite to navigate to I tap the map screen, wait for 3 seconds, then tap the navigate to icon, wait for 3 seconds, then tap the favourites icon, wait for 3 seconds and then tap the line entry.
At least one can 'pre-tap' the screen areas quickly in succession and the menu will eventually catch up - so whilst the screen still shows the 'main menu' I can already tap on an icon that has not yet come up and it will process the correct command eventually once it displays the correct sub-menu.
This sluggishness just makes using the device unpleasant and shows how underpowered it really is. The software has advanced much faster than the hardware or maybe it's just very inefficient code.
Guivre46
PostPosted: Fri Jun 01, 2012 10:46 am    Post subject: Reply with quote
Know nothing of MyTomtom devices. Slow screen taps on the older devices was nearly always software related.
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
PostPosted: Fri Jun 01, 2012 11:07 am    Post subject: Reply with quote
New devices are generally much slower to react to screen presses than old ones (that's TomTom's idea of progress).
But if you are getting upwards of 3 seconds delay regularly, that's way beyond normal expectations.
About all you can try is
1. Do a reset - Hold down the power buttonfor ~20 seconds UNTIL the drum roll then release it.
2. remove any custom POIs car cursors etc. temporarily, just to see if it makes a difference
3. Return to factory settings (from the menu)
4. Reinstall software using 'recovery mode'.
To go to recovery mode - Hold down the power button as if you are doing a 20-second reset, but keep the button pressed AFTER the drum roll until the black and white info screen appears, then release it. Then press it again rapidly three times 1-2-3.
Once you have the "spinning cogs" graphic, connect to MyTomTom and it should re-download the latest stable software release.
"Settling in nicely" ;-)
cabmanuk
PostPosted: Sat Jun 02, 2012 3:09 am    Post subject: Reply with quote
Thanks Andy_p Smile
scotty76
PostPosted: Thu Jun 07, 2012 8:28 pm    Post subject: Reply with quote
Did any of the suggestions fix it? My Via Live 120 seems very slow after the last update too. Sad
23.011 (02 Jan 25)
