bazzza Frequent Visitor
Joined: Nov 05, 2006 Posts: 260 Location: East Yorkshire
Posted: Sun May 27, 2012 7:24 pm Post subject: Lost speed camera voices |
I seem to have lost my speed camera voices. The cameras show on the screen but no voice. Voice for directions (Jane) works fine.
For every camera in the cameras file there is .bmp, .ogg, .Ov2, .bmp.
Can anyone help?
I tried searching but can't find anything. _________________ Bazzza
TTGO520 Version 9.430
Western & Central Europe Maps
Iphone 6
TT Via 135M
GO520 WiFi |
newtomoneowner Pocket GPS Verifier
Posted: Sun May 27, 2012 9:06 pm Post subject: |
Have you set the unit to warn when approaching a POI, you have to go into the menu and manage POI's then find the icon for warn when near, you then have to browse to the correct POI and choose which sound you want.
You may have set them before, but ive had my TT1 crash and all warnings and home location got reset to defaults. _________________ Call Me N3wt for short.....
Gone back to XP after trying Windows 7, it was nice but i still prefer XP |
Posted: Sun May 27, 2012 9:18 pm Post subject: Speed camera voices |
Thanks, I'll have a look at that.
BTW I can't get on with 7 either. _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
Posted: Sun May 27, 2012 9:34 pm Post subject: speed camera voices |
That seems to be ok. Where should the sound files be? _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
DennisN Tired Old Man
Posted: Mon May 28, 2012 10:24 pm Post subject: Re: speed camera voices |
bazzza wrote: | That seems to be ok. Where should the sound files be? |
WHAT seems to be OK? The sound files should be where you've got them - you said every camera has .bmp, .ogg, .ov2 and X2.bmp. The ogg file is the voice.
When you manage POIs, Warn when near POPI, choose the first camera, set the distance. At some point it asks "Is this the sound you want?" and you answer YES - BUT there is no sound to listen to! Do that with all cameras. You do NOT choose the sound you want, the voice warning is picked up by matching the .ogg filename to the ,ov2 filename. _________________ Dennis
Two of them are obesiting!! |
MikeGordon Lifetime Member
Posted: Tue May 29, 2012 7:04 pm Post subject: Lost speed camera voices |
This happens to me after major map updates. I have discovered that everything previously loaded up to Red Traffic Lights work but the rest do not. It seems as if the .ogg files get corrupted. I find that removing the old version of the .ogg files and reinstalling from my backup, then redoing the warning tick does the trick.
This has happened for the past two years on my 930 and I have just got used to it
Mike |
Posted: Tue May 29, 2012 7:14 pm Post subject: Lost speed camera voices |
Thanks Mike. I have just done a map update. _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
Posted: Tue May 29, 2012 8:07 pm Post subject: Re: speed camera voices |
Thanks Dennis, they just needed re-doing. OK now.
ps. Mike. I didn't need to re-install the ogg files. _________________ Bazzza
Iphone 6
TT Via 135M
GO520 WiFi |
Posted: Tue May 29, 2012 9:55 pm Post subject: Re: Lost speed camera voices |
MikeGordon wrote: | This happens to me after major map updates. I have discovered that everything previously loaded up to Red Traffic Lights work but the rest do not. It seems as if the .ogg files get corrupted. I find that removing the old version of the .ogg files and reinstalling from my backup, then redoing the warning tick does the trick.
Mike |
If you have a look at your files, I think you'll find an odd one that is relatively new - VARIABLE? And doesn't have an ogg file. Or a pMobile file of that nature. Or maybe Specs 20. All it needs is to get a download of the ogg file for that particular camera. Sorry this is not too clear, I can't for the life of me remember what camera type caused the problem. Just look at them all and make sure you've got an ogg for every one. _________________ Dennis
