Pocket GPS World :: View topic - Strange Speed Alerts
alanw47
PostPosted: Thu May 24, 2012 9:23 am    Post subject: Strange Speed Alerts Reply with quote
I have a Nuvi 1340T which normally behaves impeccably. Following a replacement to my PC I had to reload all my software and inadvertently loaded sox version 14.4.0 instead of 14.0.1 (together with the 3 dll files). All seemed fine until I encountered the first camera - Normally it would be Mobile Camera 60mph. The alert I actually received was "Average Speed Camera, Unknown Speed Limit" Every other version of sox produced the same alert until I got back to 14.0.1 when normal service was resumed. Does anyone know why this should be? Has it happened before? I'm perfectly happy having reverted to 14.0.1 but I really don't understand how the wrong alerts came out.
PhilHornby
PostPosted: Thu May 24, 2012 1:28 pm    Post subject: residual file from previous run? Reply with quote
Presumably you managed to restore an old .WAV output file from the last time the correct version of Sox ran. If the new version of Sox wasn't running, or was producing a file of a different name (that POILoader wasn't expecting), that might explain it - it would keep finding the same output file every time, no matter what the source file contained.
alanw47
PostPosted: Thu May 24, 2012 1:35 pm    Post subject: Strange Speed Alerts Reply with quote
The .wav files themselves hadn't been corrupted, the Garmin was just giving the wrong one every time until I restored the old version of sox, having done that all is well again. I didn't have to change anything other than that.
PhilHornby
PostPosted: Thu May 24, 2012 1:41 pm    Post subject: Re: Strange Speed Alerts Reply with quote
alanw47 wrote:
The .wav files themselves hadn't been corrupted,.
I didn't mean your .WAV files...
Sox is used to manipulate your input .WAV file into something like Output.wav every time it runs (I can't remember the exact command line POILoader feeds it). It is that Output.wav that POILoader then writes to the .GPI file. (IIRC Sox is used to change the bitrate and no. of channels of each .WAV file that POILoader encounters)
If no new Output.wav gets created, but there was an old one lying around, it could explain your symptoms.
alanw47
PostPosted: Thu May 24, 2012 1:51 pm    Post subject: Strange Speed Alerts Reply with quote
Thanks for your answer even though I don't fully understand it. I'll try uninstalling and reinstalling POILoader and try again, if that doesn't work I'll just stick with 14.0.1
