Pocket GPS World :: View topic - Camera Manager digital certificate at startup
borgmaster
PostPosted: Fri May 18, 2012 10:17 am    Post subject: Camera Manager digital certificate at startup Reply with quote
Since upgrading to FF 12 my computer at start up keeps asking for a digital certificate for CM. I have to click on run for my computer to continue to load and eventually CM is loaded ok. Is there a way of getting round this? I`m using Vista 32 Bit home premium.
PostPosted: Fri May 18, 2012 11:09 am    Post subject: Reply with quote
Do you want two answers to your two identical posts, or will just one do? Rolling Eyes
dales
PostPosted: Fri May 18, 2012 11:22 am    Post subject: Reply with quote
I make it three identical posts!!
Dales
nuvi 2599LMT-D, oregon 700, basecamp, memory-map.
borgmaster
PostPosted: Fri May 18, 2012 5:00 pm    Post subject: Reply with quote
Sorry as I had no response to one question I thought it may be because I had not put it in the correct place. So thought I would post in another section. Then I got told 15 secs to google an answer. I have been googling the issue for ages and have tried all the solutions I have found on there first. Gpedit not on Vista home premium, cmd (running as administrator) and using Bcdedit.exe /set nointegritychecks ON does not work either. etc etc
Sorry for not meeting the high standards of protocol by a couple of members of the forum but just looking for an answer. Thought this forum would provide the necessary experts of CM after I have exhausted the google options.
In future I will be aware that I must ask only once to meet the criteria of any one who is pedantic and counts the number of posts made on an issue. Consider me chastised.
PostPosted: Fri May 18, 2012 6:40 pm    Post subject: Reply with quote
My guess would be that the majority of regular experienced 'forumers' use the 'New Posts' menu option below 'Forums'. This picks up all the posts since your last visit. It can return quite a lot of posts if you don't visit often though. The forum rules also state that you shouldn't post the same question twice. I've had another good Google around, and can now sympathise with your frustration. It took me ages to find that Microsoft have made it so that you can't autorun a program via a .ini file from a USB device in W7 Sad
22.062 (12 Jun 24)
