Pocket GPS World :: View topic - winzip cannot open this file ????
lostgerry
PostPosted: Wed May 09, 2012 11:28 am    Post subject: winzip cannot open this file ???? Reply with quote
Hi can someone please tell me what I am doing wrong I have widows xp with winzip and when I download the poi thingy for my tom tom (France supermarkets) it says it cant open it and its not valid download again done this about 10 times and rebooted tried a few time and same thing ?
sorry if I am missing something obvious ??
thanks for reading Smile
PostPosted: Wed May 09, 2012 11:55 am    Post subject: Reply with quote
Have you tried to d/l a different set of POIs to see if that file is also 'dodgy'. It might be worth a try.
PostPosted: Wed May 09, 2012 12:36 pm    Post subject: Reply with quote
after you select 'France' are you clicking on the 'Refresh POI List'?
are you combining the subcategories into a single file?
have you tried the 'show link' option?
what format file are you requesting?
Anita
PostPosted: Wed May 09, 2012 12:38 pm    Post subject: Reply with quote
Have you tried the suggestion shown under the Download button?
[use 'show link' if you have problems opening the file once downloaded or it appears to be empty]
Edit: Oops. Beaten to it by MaFt!
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
PostPosted: Wed May 09, 2012 12:56 pm    Post subject: Reply with quote
If it's a normal Zip file then right click it in XP and select 'Extract'.
PostPosted: Fri May 11, 2012 2:19 pm    Post subject: Reply with quote
As Kremmen says... no need to use WinZip. Just using the built-in Windows extractor should work, so that removes one variable while we try to work out what's going wrong.
"Settling in nicely" ;-)
lostgerry
PostPosted: Thu May 17, 2012 10:10 am    Post subject: Reply with quote
Still no joy will try and get them somewhere else its only the french supermarkets I Wanted thanks anyway
PostPosted: Thu May 17, 2012 12:47 pm    Post subject: Reply with quote
I'm intrigued now... can you email me the zip file you downloaded to MaFt AT pocketgpsworld DOT com ?
I want to see if there's an issue with the zip file or if it's a winzip issue.
JoeGriffin
PostPosted: Thu May 17, 2012 2:12 pm    Post subject: Re: winzip cannot open this file ???? Reply with quote
I found a similar thing. Instead, I checked the "Show link" box. That means you end up with a link to the ZIP file. Click that and it downloads. I've found that I get the file correctly each time I do that. If I don't check the "Show Link", it automatically downloads, but I get an un-openable file.
Hope that helps.
... Joe
Garmin Montana 610
Garmin DriveSmart 51LMT-D
Garmin Nuvi 2599LMT-D
lostgerry
PostPosted: Thu May 17, 2012 4:43 pm    Post subject: Re: winzip cannot open this file ???? Reply with quote
Hope that helps.
Joe your right did what you said and yippeee thank you very much
Daggers
PostPosted: Thu May 17, 2012 5:06 pm    Post subject: Reply with quote
Isn't that one of the ideas that MaFt suggested in his first answer? ... and also what Anita suggested?
Garmin DriveSmart 50 LMT-D
PostPosted: Thu May 17, 2012 7:06 pm    Post subject: Reply with quote
Yes, but that was a week ago for goodness sake Very Happy Very Happy
lostgerry
PostPosted: Thu May 17, 2012 8:03 pm    Post subject: Reply with quote
oiy I will have you know I have had a buss pass for the last 6 years sometimes I dont get it the first time
dont worry it will come to you and the next step is smellin of stale pee !! oh deep joy
PostPosted: Fri May 18, 2012 12:01 am    Post subject: Reply with quote
Don't come the Oi with me Very Happy . I already smell of stale pee and have had a bus pass for longer than you and nearly as long as DennisN Very Happy Happy Birthday!
And I did put a couple of smileys after my comment
lostgerry
PostPosted: Fri May 18, 2012 10:20 am    Post subject: Reply with quote
if your youryour trying to make me feel worse its working dad Embarassed
