Pocket GPS World :: View topic - give me this reggfile...
jlw
PostPosted: Mon Aug 30, 2004 7:23 pm    Post subject: give me this reggfile... Reply with quote
can someone plz give the this regfile: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{e
0cbf06c-cd8b-4647-bb8a-263b43f0f974}
I deleted it.. Followd this
http://support.microsoft.com/default.aspx?scid=kb;en-us;883258
Warning If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
What can I do if my Bluetooth devices do not function?
If your Bluetooth device functioned correctly in Windows XP SP1, some Bluetooth drivers may not have updated correctly.
To resolve this issue, follow these steps:
Click Start, click Run, type regedit, and then click OK.
Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{e0cbf06c-cd8b-4647-bb8a-263b43f0f974}
On the Edit menu, click Delete.
On the File menu, click Exit to quit Registry Editor.
Click Start, click Run, type devmgmt.msc, and then click OK.
Locate and then click the Bluetooth radio device.
On the Action menu, click Uninstall to remove the Bluetooth device.
After the Bluetooth device has been removed, click Scan for hardware changes on the Action menu.
After the Bluetooth device has been correctly detected, Windows XP SP2 Bluetooth drivers are installed. On the File menu, click Exit to quit Device Manager.
Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Kingston Elite Pro 512 MB
CF: Lexar 256 MB
Poporta Alu-Case
PostPosted: Mon Aug 30, 2004 7:27 pm    Post subject: Reply with quote
The export of that key from my machine, running WinXP Pro SP2 can be downloaded here.
jlw
PostPosted: Mon Aug 30, 2004 7:43 pm    Post subject: Reply with quote
If you ever want a kiss or a hug from a swedish viking.. send a pm to me :D
Fortuna Clip-On
CF: Lexar 256 MB
Poporta Alu-Case
PostPosted: Mon Aug 30, 2004 8:19 pm    Post subject: Reply with quote
If you were a tall blonde female Swede then I'd accept but sadly you are not, still I'm pleased that you are happy Laughing
22.055 (29 May 24)
