psimon Occasional Visitor
Posted: Fri Aug 27, 2004 11:44 pm Post subject: Problems with Bluetooth Dropouts |
I know that there has been a lot of discussion on Bluetooth and dropouts / problems on this board already.
I have got to a point after following the numerous advice dotted around this forum where I am pretty stuck, any assistance would be gratefully received.
I am using an IPAQ 5450, Tom Tom Bluetooth GPS, Navigator 3, GPS driver 2.07, Memory Map, sandisk SD 256Mb, PPC 2003 - ROM 2.00.21 ENG, IPAQ Bluetooth driver - 1.4.1.58 (latest)
My IPAQ connects to the GPS receiver fine, and will stay connected for some time. However if I change from Navigator view to Map view it will frequently lock up. If I interrogate the GPS status it will show the black dots stuck on 4, and lock all other detail. Sometimes this does not occur, but if I start to scroll the map around it will eventually lock. This occurs whether the map is on my SD card or within main memory (card removed). Therefore I do not think it is a card problem.
A soft reset will normally cure the problem, however on occasion I have to power cycle the BT GPS.
I have also been having similar problems with Memory Map. Memory Map will find the GPS okay and will give me a fix. However if I scroll the map or zoom out I will lose the GPS receiver - a message of GPS: communication timeout will be given. GPS config on Memory Map is NMEA, COM8 and 4800.
I have also tried removing TTN 3 - MM problem still exists
I have also tried removing MM - TTN3 problem still exists
Incidentally the problems above also occured with GPS driver 3.03
I am really at a loss as to what to do next,
Psimon |
MrT Frequent Visitor
![](modules/Forums/images/avatars/gallery/065.gif)
Joined: Nov 14, 2003 Posts: 2143 Location: Surrounded by A1, M1 & M25
Posted: Sat Aug 28, 2004 7:55 am Post subject: |
This sounds like it happens when the PDA is reading map data which points to a memory error.
Try and put a small map in the iPAQ internal memory rather than on the storage card and see if you still have the same problems. If this stops the problem it could be a storage card incompatibility.
Also TomTom seems to sometimes object to certain other programs running such as Calendar and Active Synch.
It could be that your internal memory is full, look under settings-memory and see how much free memory you have.
Also try placing the TT BT unit close to the PDA (<0.5m) and see if that improves the situation. If I place myself between the PDA and the TT unit, that can often be enough to block the signal. |
Posted: Sat Aug 28, 2004 11:09 am Post subject: |
Mr T,
Thanks for the prompt reply.
I think your assessment appears fairly accurate - i.e. memory problem.
The communication failure only seems to occur whilst manipulating map data.
Couple of points in answer to your questions:
1. Have tried small maps in internal memory - still the same problem.
2. Have had no other programs running in background i.e. Activesync / Calender - still the same problem
3. Internal memory seems to be okay, I have around 23Mb for running programs.
4. Most of the time the reciever is fairly close to the PDA - still the same problem.
I am really get quite frustrated - I am beginning to wonder whether I should give up on it all. It certainly is no good if Bluetooth drops everytime I adjust the program / maps.
I think I shall try a complete re-install and see if that helps - I fear not as the problem is common across Tom Tom and Memory Map
Psimon |
Posted: Sat Aug 28, 2004 7:34 pm Post subject: |
Okay, as an update.
I have hard reset the IPAQ. Have only had Tom Tom loaded and maps in Internal memory. The problem still persists!
I have noticed something else:-
Once communication is lost between the IPAQ and the Receiver I have to often soft reset the IPAQ. On a number of occasions once I have soft reset and started to run TTN again the receiver will power off completely.
There seems to be so many symptoms and little resolution, I am wondering whether I have duff hardware.
Simon |
alix776 Pocket GPS Moderator
![](modules/Forums/images/avatars/6212487444319be6786243.jpg)
Posted: Sat Aug 28, 2004 7:51 pm Post subject: |
try unchecking the show poi in the poi submenu in prperties and make sure the reacive all beams in unchecked so the ir is turned off _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
bigfatjohn Regular Visitor
![](modules/Forums/images/avatars/8066613804237dc96e852b.jpg)
Joined: Oct 29, 2003 Posts: 114 Location: Market Harborough
Posted: Sat Aug 28, 2004 10:04 pm Post subject: |
I suffered badly from this problem.
The only way I could cure it was to chuck the TomTom BT away and replace it with a Haicom.
![Sad](modules/Forums/images/smiles/icon_sad.gif) |
a4ace Regular Visitor
![](modules/Forums/images/avatars/9ee8373f403b702eb6e1d.jpg)
Joined: 19/08/2003 21:28:03 Posts: 219 Location: Geneva, Switzerland
Posted: Sun Aug 29, 2004 12:43 pm Post subject: |
have you tried the latest gps driver 3.03? _________________ tomtom 940 live/tt active dock holder/tt rds-tmc traffic receiver usb |
Posted: Sun Aug 29, 2004 12:47 pm Post subject: |
sorry, i saw that you have tried 3.03. do you use cpu tweaks? i use xcpuscalar and tried tweaking to 530mhz. in the middle of a 40km journey, tomtom indicated gps disabled. went back to 472mhz, all is well. _________________ tomtom 940 live/tt active dock holder/tt rds-tmc traffic receiver usb |
Posted: Mon Aug 30, 2004 8:34 am Post subject: |
Thanks for all the comments. I am sad to say that I am still have problems.
I am not using any CPU tweaks, POI turned off, IR turned off, I am using 3.03 (also tried with 2.07).
I went on a long journey yesterday and it worked for the entirety, however as soon as I 'manipulated' the map the Bluetooth connection was lost.
Simon ( still frustrated). |
Steve999 Regular Visitor
![](modules/Forums/images/avatars/13072220474315e73879ef9.gif)
Joined: Jun 20, 2004 Posts: 160 Location: Lincolnshire, England
Posted: Mon Aug 30, 2004 9:32 am Post subject: |
Just an idle thought - when you want to manipulate the map, have you tried unchecking the 'Keep GPS position on screen' option within Advanced Properties?
If this is checked, the software may object to being asked to do the impossible when you try to manually manipulate.
Steve _________________ Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
Posted: Mon Aug 30, 2004 11:17 am Post subject: |
Thanks Steve,
I checked your suggestion, however the 'keep GPS position on screen' was not checked, so this is not the problem
S. |
Posted: Fri Sep 03, 2004 9:23 am Post subject: |
Thought I would post a reply as I have managed to fix the Bluetooth problem.
I had to take somewhat drastic action - restore to PPC 2002. It really did seem that the IPAQ 5450 with WM2003 could not stabilise Bluetooth. I got the impression this had something to do with either processor power or memory leaks.
Suffice to say that using PPC2002 has solved the problem on my setup
Psimon |
