Pocket GPS World :: View topic - Problems with Bluetooth Dropouts
psimon
PostPosted: Fri Aug 27, 2004 11:44 pm    Post subject: Problems with Bluetooth Dropouts Reply with quote
I know that there has been a lot of discussion on Bluetooth and dropouts / problems on this board already.
I have got to a point after following the numerous advice dotted around this forum where I am pretty stuck, any assistance would be gratefully received.
I am using an IPAQ 5450, Tom Tom Bluetooth GPS, Navigator 3, GPS driver 2.07, Memory Map, sandisk SD 256Mb, PPC 2003 - ROM 2.00.21 ENG, IPAQ Bluetooth driver - 1.4.1.58 (latest)
My IPAQ connects to the GPS receiver fine, and will stay connected for some time. However if I change from Navigator view to Map view it will frequently lock up. If I interrogate the GPS status it will show the black dots stuck on 4, and lock all other detail. Sometimes this does not occur, but if I start to scroll the map around it will eventually lock. This occurs whether the map is on my SD card or within main memory (card removed). Therefore I do not think it is a card problem.
A soft reset will normally cure the problem, however on occasion I have to power cycle the BT GPS.
I have also been having similar problems with Memory Map. Memory Map will find the GPS okay and will give me a fix. However if I scroll the map or zoom out I will lose the GPS receiver - a message of GPS: communication timeout will be given. GPS config on Memory Map is NMEA, COM8 and 4800.
I have also tried removing TTN 3 - MM problem still exists
I have also tried removing MM - TTN3 problem still exists
Incidentally the problems above also occured with GPS driver 3.03
I am really at a loss as to what to do next,
Psimon
MrT
PostPosted: Sat Aug 28, 2004 7:55 am    Post subject: Reply with quote
This sounds like it happens when the PDA is reading map data which points to a memory error.
Try and put a small map in the iPAQ internal memory rather than on the storage card and see if you still have the same problems. If this stops the problem it could be a storage card incompatibility.
Also TomTom seems to sometimes object to certain other programs running such as Calendar and Active Synch.
It could be that your internal memory is full, look under settings-memory and see how much free memory you have.
Also try placing the TT BT unit close to the PDA (<0.5m) and see if that improves the situation. If I place myself between the PDA and the TT unit, that can often be enough to block the signal.
psimon
PostPosted: Sat Aug 28, 2004 11:09 am    Post subject: Reply with quote
Mr T,
Thanks for the prompt reply.
I think your assessment appears fairly accurate - i.e. memory problem.
The communication failure only seems to occur whilst manipulating map data.
Couple of points in answer to your questions:
1. Have tried small maps in internal memory - still the same problem.
2. Have had no other programs running in background i.e. Activesync / Calender - still the same problem
3. Internal memory seems to be okay, I have around 23Mb for running programs.
4. Most of the time the reciever is fairly close to the PDA - still the same problem.
I am really get quite frustrated - I am beginning to wonder whether I should give up on it all. It certainly is no good if Bluetooth drops everytime I adjust the program / maps.
I think I shall try a complete re-install and see if that helps - I fear not as the problem is common across Tom Tom and Memory Map
Psimon
psimon
PostPosted: Sat Aug 28, 2004 7:34 pm    Post subject: Reply with quote
Okay, as an update.
I have hard reset the IPAQ. Have only had Tom Tom loaded and maps in Internal memory. The problem still persists!
I have noticed something else:-
Once communication is lost between the IPAQ and the Receiver I have to often soft reset the IPAQ. On a number of occasions once I have soft reset and started to run TTN again the receiver will power off completely.
There seems to be so many symptoms and little resolution, I am wondering whether I have duff hardware.
Simon
alix776
PostPosted: Sat Aug 28, 2004 7:51 pm    Post subject: Reply with quote
try unchecking the show poi in the poi submenu in prperties and make sure the reacive all beams in unchecked so the ir is turned off
device Lumia 950 xl
bigfatjohn
PostPosted: Sat Aug 28, 2004 10:04 pm    Post subject: Reply with quote
I suffered badly from this problem.
The only way I could cure it was to chuck the TomTom BT away and replace it with a Haicom.
Sad
a4ace
PostPosted: Sun Aug 29, 2004 12:43 pm    Post subject: Reply with quote
have you tried the latest gps driver 3.03?
tomtom 940 live/tt active dock holder/tt rds-tmc traffic receiver usb
a4ace
PostPosted: Sun Aug 29, 2004 12:47 pm    Post subject: Reply with quote
sorry, i saw that you have tried 3.03. do you use cpu tweaks? i use xcpuscalar and tried tweaking to 530mhz. in the middle of a 40km journey, tomtom indicated gps disabled. went back to 472mhz, all is well.
psimon
PostPosted: Mon Aug 30, 2004 8:34 am    Post subject: Reply with quote
Thanks for all the comments. I am sad to say that I am still have problems.
I am not using any CPU tweaks, POI turned off, IR turned off, I am using 3.03 (also tried with 2.07).
I went on a long journey yesterday and it worked for the entirety, however as soon as I 'manipulated' the map the Bluetooth connection was lost.
Simon ( still frustrated).
Steve999
PostPosted: Mon Aug 30, 2004 9:32 am    Post subject: Reply with quote
Just an idle thought - when you want to manipulate the map, have you tried unchecking the 'Keep GPS position on screen' option within Advanced Properties?
If this is checked, the software may object to being asked to do the impossible when you try to manually manipulate.
Steve
Google Pixel 4a 5G Handset
Sygic
CoPilot
Nissan Connect
psimon
PostPosted: Mon Aug 30, 2004 11:17 am    Post subject: Reply with quote
Thanks Steve,
I checked your suggestion, however the 'keep GPS position on screen' was not checked, so this is not the problem Sad
S.
psimon
PostPosted: Fri Sep 03, 2004 9:23 am    Post subject: Reply with quote
Thought I would post a reply as I have managed to fix the Bluetooth problem.
I had to take somewhat drastic action - restore to PPC 2002. It really did seem that the IPAQ 5450 with WM2003 could not stabilise Bluetooth. I got the impression this had something to do with either processor power or memory leaks.
Suffice to say that using PPC2002 has solved the problem on my setup
Psimon
22.105 (30 Oct 24)
