IanS100 Frequent Visitor
![](modules/Forums/images/avatars/211994756248e61142ce223.gif)
Posted: Wed Feb 22, 2012 3:11 pm Post subject: |
How does the 1000/1005 et al get the updated postcode database? is it embeded in the map for myTomTom devices? |
Daggers Lifetime Member
![](modules/Forums/images/avatars/gallery/pyramid.jpg)
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Wed Feb 22, 2012 5:16 pm Post subject: |
sdm197 wrote: | Hi,
I have a tt940, I was just wondering, do the postcodes on the unit get updated when you update the map? I have signed up for the quarterly updates and wondered if there is any point of installing the codes earlier in the thread?
thanks in advance for any replies.
SDM197. |
No, they don't get updated. You should download the file quoted above, and unzip it into your "zip" folder. _________________ Garmin DriveSmart 50 LMT-D |
Andy_P Pocket GPS Moderator
Posted: Wed Feb 22, 2012 5:33 pm Post subject: |
IanS100 wrote: | How does the 1000/1005 et al get the updated postcode database? is it embeded in the map for myTomTom devices? |
That's a matter of conjecture at the moment.....
If you look at the latest maps when they have been downloaded to an OLD model (so you can see the contents) then there is a new file in the map folder that LOOKS like it is to do with postcodes.
That file doesn't get used on the older models, but it MIGHT be getting used on the new ones like the Go1000/1005.
Not easy to check though, until we have some examples of codes that were definitely wrong on v880 and that are corrected on v885.
All submissions welcome! _________________ "Settling in nicely" ;-) |
pcaouolte Frequent Visitor
![](modules/Forums/images/avatars/1614640253476fea0f01bba.jpg)
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Wed Feb 22, 2012 6:35 pm Post subject: |
I think that postcodes which differ between 880 and 885 postcode files are going to be hard to find because the file is only 1 byte different in size!
I don't know much about the new models, does the map data still get downloaded to the PC (where we can see it) before it is pushed to the device? _________________ Paul |
Posted: Wed Feb 22, 2012 6:54 pm Post subject: |
Yes, with the regular TomTom home devices save it to the the PC before dumping it on the TomTom! |
Posted: Wed Feb 22, 2012 6:58 pm Post subject: |
Yes, but what about the new devices, do map updates still get saved on the PC before they a dumped to the device where they can't be seen? _________________ Paul |
Posted: Wed Feb 22, 2012 7:01 pm Post subject: |
No, not on the new devices |
Posted: Wed Feb 22, 2012 7:06 pm Post subject: |
Ok, thanks. If you have one of these new, locked down devices do you know what map version (and therefore probably what postcode file version) was on it when you bought it? It should be easier to identify changes in the postcode file between a fairly old version and the latest version. _________________ Paul |
Posted: Wed Feb 22, 2012 7:13 pm Post subject: |
On the TomTom Home devices the information on Navcore & Map versions is available directly from the device & imagine it's the same for the 1000/1005 et al |
Posted: Wed Feb 22, 2012 7:19 pm Post subject: |
If we could find someone who knew that their 1000/1005 device came with a map version of say 850 then it would be likely to have postcode file version 850 on it.
If they have now updated to map version 885 and we can identify a postcode which has changed between version 850 and 885 postcode files then we can check if it is changed on the device. This seems to be the only way to find out if the postcode file is being updated on the locked down devices. _________________ Paul |
Posted: Wed Feb 22, 2012 7:29 pm Post subject: |
Identifying a changed postcode is the problem |
satsam Lifetime Member
![](modules/Forums/images/avatars/gallery/003.gif)
Posted: Thu Feb 23, 2012 10:55 am Post subject: Postcodes |
Can I use Version 885 postcodes on a Go 500 with United Kingdom and Republic of Irland Map V880.3868. also on a Go950 Live with Map Europe V875.3612? _________________ TomTom 500, 2GB, App. 7.903,(9183/081205 OS 2344 Map:United_Kingdom_and_Republic_of_Ireland V900.4602
GO LIVE 950, 12GB App. 9.465.1074274.1 OS 842337 (2025, 27/9/2012 Map: Internal United_Kingdom_and_Republic_of_Ireland V900.4602 SD card Europe V880.381 |
Guivre46 Frequent Visitor
![](modules/Forums/images/avatars/gallery/hiro_bird.jpg)
Joined: Apr 14, 2010 Posts: 1262 Location: West London
Posted: Thu Feb 23, 2012 11:00 am Post subject: |
Our Certified Genesis said you could, and 885 postcodes work on my 860WE map. _________________ Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom |
Posted: Sun Feb 26, 2012 7:46 pm Post subject: |
AB101AA is not in the latest 885 postcode file but was in 880, 875 and 870.
So if someone with one of the new locked down devices (GO1000 etc) and the latest 885 map could check if they have the postcode AB101AA then we will know if those devices are now using the new postcode files contained within the updated map. _________________ Paul |
BorisBlank Occasional Visitor
Joined: Dec 25, 2006 Posts: 16 Location: United Kingdom
Posted: Mon Feb 27, 2012 9:35 am Post subject: |
pcaouolte wrote: | AB101AA is not in the latest 885 postcode file but was in 880, 875 and 870.
So if someone with one of the new locked down devices (GO1000 etc) and the latest 885 map could check if they have the postcode AB101AA then we will know if those devices are now using the new postcode files contained within the updated map. |
Nope, my 885 updated GO1000 does not recognise AB101AA. |
